Closed Thread
Old 11-06-2011, 12:04 AM   #4176
thebatii
thebatii's Avatar
Re: What did you do to your truck today?
some other shots
thebatii is offline
Old 11-06-2011, 12:40 AM   #4177
el_bole
Man those interiors and gauges look great fellas....Hoping to add a big back window to my '61 in the near future....
Today I thought I was going to be busy mocking up my '61 apache cab onto my '73 frame but it was smoother than I thought to use the cherry picker to swing it onto the chassis....Gettting it ready for welder to come over on Monday to measure out where the cab mounts are gonna go, thats why clip is misaligned.......here's a few after pics.
Last pic is just of the chassis itself...all and any constructive critisism welcome...
el_bole is offline
Old 11-06-2011, 01:51 AM   #4178
losthope
losthope's Avatar
Not a Damn thing !! its raining and my garage is a concrete driveway so the roof doesnt shed water to well.......
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline
Old 11-06-2011, 04:41 PM   #4179
DLOE65
DLOE65's Avatar
welded in the hole where the radio used to be, made a great spot for my manual air ride valves. Still need to grind it down and make it look pretty.. good enough for today.
DLOE65 is offline
Old 11-08-2011, 02:15 PM   #4180
QWYKTRUK
I finally got around to getting the motor de-tuned and dyno'd . I took it over to my friends shop in Phoenix - ProDyno. He does great work! I know the video is kinda boring but I didn't want to get slammed for not posting pics...lol.
A little warm up and a short run came out with 607 horsepower and 555 ft. lbs of torque at the rear wheels. The smoke at the end of the run actually cleared up after a few minutes, I had it running rich for so long it needed to clean the crap out. Had to adjust the timing back to 32 degrees and change carb jets from 108/103's to 95/93's . Taking 12% out of the blower made it more streetable. I can now run on 112 octane instead of 118. Over $4 per gallon savings!
I can actually drive it to Dino's party!!
QWYKTRUK is offline
Old 11-08-2011, 10:42 PM   #4181
shortbed70
shortbed70's Avatar
Dang I wish I could de-tune my motor to make that power!!! Nice...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline
Old 11-08-2011, 11:46 PM   #4182
tincan1966
tincan1966's Avatar
Didn't get any pics, but made my own rack and pinion conversion crossmember today. Will install the rack and tie rod ends tomorrow. Moved the stock main crossmember forward 1 inch to center the wheel in the openings better. new engine should be here by weeks end. Hoping to have eng/trans in and roling chassis by Thanksgiving. Have all of the painless wiring chassis, efi and phantom key systems to install. Aiming for the all truck Nats in KC next year.
tincan1966 is offline
Old 11-09-2011, 12:45 AM   #4183
Vernski
Qwyktruk that cartoon would look great on a t-shirt way cool...Vernski
Vernski is offline
Old 11-09-2011, 09:49 AM   #4184
QWYKTRUK
Thanks Vernski! I had some made up years ago and they did come out nice.
I'm thinking about getting some more done...if I could only find the artwork...lol
Q
QWYKTRUK is offline
Old 11-09-2011, 01:57 PM   #4185
doublebeetx
Hey tincan, what was involved in moving your crossmember forward ? Did you narrow it to fit the frame ?
doublebeetx is offline
Old 11-09-2011, 02:12 PM   #4186
E911manager
Pulled the body off the caprice frame without getting killed...
E911manager is offline
Old 11-09-2011, 10:20 PM   #4187
towersddg9
towersddg9's Avatar
Installed my driveshaft from Denny's, fit good, when I ordered I requested 3 inch, my truck is short bed, but I moved forward a hole on the eng perch, 700r4, Denny's suggested a 3.5inch due to length, two weeks turnaround excellent quality, arrived ready to install yoke and ujoints
towersddg9 is offline
Old 11-10-2011, 03:05 AM   #4188
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Took Tanya down to the AAA aproved auto shop to get her tailgate looked at. I finally got the adjuster to call me back, so hopefully this can be over with in a few days and I can start looking for a good tailgate, and finally move on with the project.
One good thing came of today: The guy that own this shop is an old friend of mine who had not seen Tanya yet. When we started talking about my plans for her he got really excited saying how he loves working on these old trucks. He offered to come to my shop and guide me through some of the rust repairs, and even help coach me on painting. Ray (the shop owner) has been doing body work for a very long time, and I've seen some really quality resorations that he has personally done, so I'm really stoked on what this means for Tanya! In turn He asked if I could come over tomorrow and help him fire up his 'Cuda he's been working on.....first time fire on a 440 'Cuda......I'd be crazy not to. Today was a good day.
fryer1979 is offline
Old 11-10-2011, 07:23 AM   #4189
tincan1966
tincan1966's Avatar
Thumbs up Re: What did you do to your truck today?
Actually, I made my own new front crossmember. Sounds strange but I am using stock control arms, but moved forward 1" and the control arms mount 1 1/2" higher. Also added rack and pinion steering. will take some pics this weekend after final fitting. There's a method to my madness here - I really just wanted to see if I could achieve the stance I wanted.,without a $2000 front suspension kit. As a failsafe- always have to stocker to put back in!
Old 11-10-2011, 07:33 AM   #4190
tincan1966
tincan1966's Avatar
forgot to add. If this all squares up, hitting the frame shop to double check dimensions and alignment, then will gladly pass along the measurements. It's nothing that hasn't been done before, just wanted to try it Certain amount of pride in doing it yourself. Crossmember is all 1 1/2 tubing 1/8" wall thickness from a chassis shop. It bolts in to stock frame holes,upper control arm only moved forward 5/8" and added 3 degrees more antidive. Only set up for air ride, but if it works correctly, will make a version for coil springs or coil overs.
Old 11-11-2011, 12:52 AM   #4191
X24
Today i threw away the crappy pepboys brake lights that came on my truck and installed some quality BROTHERS cans.
It would've been pretty easy except for the having to solder a ground to the brake lights bulb housing. This made them WAY brighter. I also ran my own wires and used heat shrink and nylon wire dressing in place of the cheesy plastic that came with them. This is only 1 out of 200 on my list of things to do.
X24
1964 chevy c10 step side
230ci straight six
Auto power glide
X24 is offline
Old 11-11-2011, 01:00 AM   #4192
X24
i forgot to add images for everyone.
X24
230ci straight six
Auto power glide
X24 is offline
Old 11-11-2011, 01:17 AM   #4193
X24
X24
230ci straight six
Auto power glide
X24 is offline
Old 11-12-2011, 12:04 AM   #4194
towersddg9
towersddg9's Avatar
Bout ready to fire it up, need to put the column in, clean up several grounds on the frame, wire up the radio install the kick panels, bought a set with some good pioneer speakers test fit good
Old 11-12-2011, 08:33 AM   #4195
kieth
kieth's Avatar
Installed a Craftec tonneau cover on my 66 gmc swb fleetside.....it has gas shocks and is reasonably priced.....will post pictures later today...
kieth is offline
Old 11-12-2011, 08:54 AM   #4196
kieth
kieth's Avatar
Here is a picture of the truck during trial fittting, rear corners do not have all components installed yet so that is why they are sticking up, it went pretty easy for a initial prototype install.
Here is the only modification we had to make to install a Craftec cover on a 66 short wide (at the rear corners this small gussett had to be cut down)
Very high quality would be very easy to install after doing one, and if we had read the directions and followed them it would have been easier still. Kieth
kieth is offline
Old 11-12-2011, 07:51 PM   #4197
samuellg1977
samuellg1977's Avatar
Today, I threw out my B&M Unimatic floor shifter and took a page from Delmo's "Great big book of mods and tricks" and converted my E-brake handle to work as an automatic shifter handle. The floor shifter worked, but was really loud and clunky and whenever anyone rode in the buddy bucket, the shifter handle rubbed the back of their knee the whole time. And then, I'd get strange looks from them while reaching under their leg trying to go from reverse to drive or vice-versa. Haha.
Sam
samuellg1977 is offline
Old 11-12-2011, 08:15 PM   #4198
awbrown
Pictures SAM!
awbrown is offline
Old 11-12-2011, 08:56 PM   #4199
samuellg1977
Sorry, Awbrown. Here ya go. E-brake shifter handle. Works so much more gooder than the floor shifter i took out.
Sam
Old 11-12-2011, 09:05 PM   #4200
awbrown
You must dim your lights with your knee??? Wheres park all the way up or down ? is it faster than your b&m?? lol
awbrown is offline
Closed Thread
