Old 11-06-2011, 07:16 PM   #1
JGross
Will a rear sway bar work with under bed fuel tank
I have a 66 short bed in which i have relocated the fuel tank to under the bed. I would like to install the front and rear sway bar set from CCP. Does any one know if the tank would interfear with the rear bar?
JGross is offline   Reply With Quote
Old 11-06-2011, 10:59 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Will a rear sway bar work with under bed fuel tank
Im not certain, but most swaybars are in front of the rear axle on these trucks. Shouldnt interfere unless you put the tank in there.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
