My wife's 67 C20 is an old Forest Service Stepside with ultility boxes. The GVWR is 7500 and according to the owners manual it came equipped with 8-19.5 6 ply front tires and 8-19.5 10 ply tires in the rear. Right now it is on 7.50-16 LT on demountable 8 lug rims. Does anybody now how to determine the diameter of the original tires (i.e. 78,80 or 90 series). The differential is a 4.56:1 and the shorter tires really limit highway travel. I am considereing 235/85 16 on newer tubeless rims but I really want to know how close these taller tires are to the original diameter in order to lower the highway revs to an appropriate level.
Step Brother
Re: 19.5 Tire Size
Welcome from Knoxville Tn.....I will move this where it should get more responses....
Step Brother
![]() Join Date: Sep 2007
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: 19.5 Tire Size
Welcome from NorCal! I tried a couple different tire size comparison sites, but neither lists your original size...
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
member #16
![]() Join Date: Dec 1999
Re: 19.5 Tire Size
Heres a site that shows 34.6 diameter for a 8-19.5 10 ply. And welcome to the best truck site.
http://www.sylmar.ca/autoville/tires/truck-609029.jpg
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 06-06-2009 at 06:32 PM. |
Currently Blazerless
Re: 19.5 Tire Size
I'm running 8.00 19.5 12 ply tires on my 1 ton and they measure close to 35" tall. Thats about the tallest tire available for the 19.5 rims and they are hard to find.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
Re: 19.5 Tire Size
The formula: RPM = MPH x AXLE RATIO x 336 / TIRE DIAMETER. For maximum highway speed without changing the whole rear axle, change out the 4.56 pumpkin with a 4.10 pumkin and use the period correct 19.5" wheels. Tire sizes sometimes vary between 1"-2" from different manufactures. Most 8-19.5 tires are 33" to 35" tall.
Re: 19.5 Tire Size
Just thought I would dredge this up and give a clear answer. The truck actually has a 5.13:1 axle ratio. The 235/85/16 tires give perfect speedometer and odometer readings so I suspected they are slightly bigger than stock. I eventually found the original spare and it is shorter than the new tires. Long story short: 65 MPG = 3800 RPM = 14 MPG out of a 250 six.
Re: 19.5 Tire Size
Yeah,those 19.5s were a bit short on the sidewall height,just like 16.5s. They were a lower profile diameter. You could probably go to 255/85s for a bit lower RPMs. But,that rear could change right out with a 4.10 with minor work. Just un-bolt the driveshaft and slip the axle shafts out and you can remove the entire differential from the front.
