#176 |
Re: Post Pics of your Static Drops!!
Wheel Vintiques Smoothies, chrome outers with black centers. I have 2 different sets of hub caps for them.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#177 |
I haven't put in a notch (yet), I am considering one of the Porterbuilt bolt in C notch though. As with all of Nate's products it appears to be outstanding. I'm only going to do so in an effort to gain more load carrying ability. Probably will add some helper bags so i can tow my boat.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
#178 |
Hmm. cant decide what to do. I have factory overloads on my truck that are nice but sure arent usable once lowered....
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air. |
#179 |
2.5" drop spindles w/3" drop coils in front. 5" coils w/2inch blocks on back.
#180 |
Hey badriand...
You just have coils and shocks on the back, or a cnotch too? What about panhard bar or shock relocators? I'm about to buy a 3/5 spring and shock kit and am wondering if I will be ok in the back with just that, thanks! Posted via Mobile Device |
#181 |
Oops for to add ApacheWillard. Yea i have a C-notch on back and a shorter panhard bar. No shock relocators. I did a notch with 5" coils on back and had tons of clearance ( at that time really didn't need notch). Now that i have added 2 inch blocks with the 5 inch coils i need the notch. Can't say for sure if you need notch or not (you can always add later or just take coils off and drop truck down and see what kind of clearance you have without notch.
#182 | |
#183 |
![]() Join Date: Oct 2010
I also did mine 5" and 7"
front- 3" springs-2" spindles rear--5" springs-2" block (slightly shaved and angled for pinion) I C-notched the frame along with an adjustable panhard bar. The top of the rear is actually closer to the bed wood than the rear to the C-notch. I have about 3" from the rear to the wood. No problems though 20" wheels all the way around ![]()
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
#184 |
#185 | |
#186 |
Here is a shot without caps on. Looks better maybe.
#187 |
here's mine front has POL tubular UCA/LCA, 2.5" drop spindles, CPP 3" drop springs. the rear just has CPP 4"drop springs
the Stealth Weapons 63 project, all comments, advice, and critiques welcome! http://67-72chevytrucks.com/vboard/s...d.php?t=438235 |
#188 | |
Also what size tires are you running? Looks good.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#189 | |
here are a few more for reference ![]() ![]() ![]()
#190 |
Sorry it took so long for response...... no c notching. use regular 87 shocks in front, trimmed half the bump stop off. it will sometimes bottom out in a hard dip in the road... used stock rear shocks...
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 |
#191 |
3" drop CPP Springs in the front,6 inch drop ECE coils in the rear.
#192 | |
haha sweet! ![]() |
#193 |
Can you tell me about notching the 62 frame? I've got to do it yet... thanks.
Last edited by robber grin; 04-14-2012 at 06:44 AM. Reason: added my year to the question |
#194 |
New to the forum and thought I'd learn about posting pictures. This is my work in progress/daily driver when theres not 6 feet of snow blowing around way up here. It's only lowered a little but I figure that counts for something.
#195 |
I see alot of people on here with six lugs who say they are using drop spindles. What spindles are you using, and did you have to change to disc brake set up? What rotors are you using if so?
#196 | |
The aftermarket drop spindles that you see are set up for HD brake using the 1 1/4" rotors vs the LD 1" rotors. So if you buy the drop spindles you can run stock HD 1 1/4" 5 lug rotors or aftermarket 6 lug rotors... OR you could run the 6 lug rotor on a stock HD spindle if you don't want the drop. I'm unaware of a LD brake rotor option that would allow you to run 6 lug wheels... Let us know what you come up with and PICS are always fun too! Last edited by robber grin; 05-01-2012 at 08:50 AM. Reason: spell in korecshun |
#197 | |
#198 |
ccp drop springs, notched in rear
#199 |
that thing looks awesome.
BaBaBooey BaBaBooey ![]() GO SPURS GO!!! |
#200 |
cut 1.5 coils up front off of stock spring; rear has 1998 jeep grand cherokee rear coils with 1 coil cut and 1-5/8" lowering blocks (they were 2" blocks)
rides smooth and handles great for a cheap drop ![]()
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
