Closed Thread
Old 11-08-2011, 12:13 AM   #201
mknittle
mknittle's Avatar
Re: What Did You Do With Your Truck Today ?
Originally Posted by FFredo View Post
Thanks for the input guys. First, the pic is not in my neighborhood. I was at a picnic put on by a local car club.
The bumper will flow a lot better once I cut the mounts to tuck it in closer to the frame. If not then I'll look at making a diff bumper fit. Dan, yeah I'm going with stainless 1 1/2 sounds about what I'm thinking too. Not sure if I'm going to rabit in a groove or not. All of that will decide it'self once I get the fender wells I guess.
I've looked at the truck stop lights and there are a few that are just ok. However I have had good luck making my own lights for my bikes so I'm going to give the truck lights a shot. Here's a pic of one I made for my home built bike. I used the parts from an old MAG-LITE and cut down my own lens out of your basic reflector sold at any auto parts store. It's filled with a 36 LED cluster and bright as all get out.
All I have to do is fab up the buckets. I'm going with a 2 1/2 OD lens frenched onto the frame of the bed. Two lights on each side.
that's too cool!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 11-09-2011, 02:06 PM   #202
FFredo
Thanks Mark, I plan to use 2 1/2 exaust tubing to make the buckets for the tail lights.
LED Clusters are available from several outfits. It's looking like about 100 bucks total by the time I finish the lights out.
Also I keep changing my mind on the gates. Now I'm looking at steel tube frames with sheet metal fillers vs wood stakes and planks. This will let me design a more radiused look vs. square. I think that will match the roundness of the trucks cab better. I still need to decide on how I will attach tie downs too. Probably will go with the inset type that screw into the floor, however I will add backing plates under the bed of the truck. I don't want to lose a bike going down the road.
Like you say "Indesision is the key to flexibility"
FFredo is offline
Old 11-09-2011, 02:15 PM   #203
mknittle
mknittle's Avatar
have you considered rub rails for tie downs?
It all sounds good . It will be interesting to see how it works out.
Mark
My GMC build.
mknittle is offline
Old 11-09-2011, 11:49 PM   #204
chrisg_ky
Well yesterday i got my Inner front fender sanded , primed in black and sprayed rubberized undercoating on the wheel well side.
chrisg_ky is offline
Old 11-10-2011, 01:03 AM   #205
Atommik
Atommik's Avatar
I got the final primer coat on the left rear fender. Tomorrow I am bringing the right door in to work, to tear it down (regulator, latch and handle) then start on the rust clean up and fixing a few dents.
Also tested the "BMW" xenon headlamp conversion. It is going to work great!!
Atommik is offline
Old 11-10-2011, 08:40 AM   #206
Purec4
Purec4's Avatar
Got the bedliner applied to the cab floor, both inside and out. Will need one more quart to finish, two quarts total. Happy with how it looks, hope who ever buys it will
We lust for what we want, weep for what we need...
Purec4 is offline
Old 11-10-2011, 10:52 AM   #207
Dan in Pasadena
Dan in Pasadena's Avatar
We don't believe you! We need pictures.
What kind of bedliner, the spray undercoater or the roll on kind?
Dan in Pasadena is offline
Old 11-10-2011, 11:02 AM   #208
Purec4
Purec4's Avatar
I used the Herculiner in the quart size since I'm only doing the cab. Turned out pretty good. like to add another coat if it allows (didn't read that far) and use a roller this time. I think that would look better, but then it will be covered in carpet. Used it for leak prevention on the new panels over the seam sealer, and I'm sure it will quiet things down some. Post up some pics tonight.
I know you have to stir the crap out of it or all the rubber stays in the bottom, DO NOT SHAKE! Why? I don't know; but it says not to.
Oh and on another note; stay away from the Rustoleum spray, might be good if you can get it out of the CAN! Waste of money at almost $8.00 a can.
Purec4 is offline
Old 11-10-2011, 01:54 PM   #209
ready2go69
Not mine but I like what he done with his truck today!!!!!!!!!!!!
ready2go69 is offline
Old 11-10-2011, 06:30 PM   #210
chrisg_ky
Today i added Tail light mounts and taillights to my flat bed truck. I mounted the mounts to the frame.
Old 11-10-2011, 08:54 PM   #211
Purec4
Purec4's Avatar
Told ya I did it!
Name:  54 floor 016.jpg
Name:  54 floor 017.jpg
Name:  54 floor 019.jpg
Purec4 is offline
Old 11-10-2011, 11:27 PM   #212
Dan in Pasadena
Okay, okay, I believe you! And it looks nice and solid too. What kind of condition was that floor and those kick panels before you painted it on? I plan to use something like this too after seeing another member's and now yours. BUt I still plan on putting Peel 'n Seal on top of it too!
Old 11-10-2011, 11:29 PM   #213
Daze57
Daze57's Avatar
readytogo69
nice truck !
Daze57 is offline
Old 11-11-2011, 08:21 AM   #214
Purec4
Purec4's Avatar
Dan,
the floors had been patched from the under side, leaving the old rusty metal on top and the kick panels were toast. I made all new panels with 18ga sheet metal and cut out the old leaving a boarder to attach to. Couldn't afford new panels at about $100.00 each side shipped, not including the kick panels. I bought the 4'x8'sheet of 18 ga for $48.00 and still have about a 1/2 left of the sheet left. The floor panels are 2 pieces each side. Formed with some angle iron, vicegrips, vice and a hammer! glued in place with body panel adhesive and a few rivets for extra measure. I double sealed it with a water/freeze resistat calk and then the bedliner. Hope I get no leaks! I secon qt. will finish the bottom and hopefully leave enough for a second coat on top, rolled on for a better finish look. Not that it really matters as it will have carpet over it.
Purec4 is offline
Old 11-11-2011, 04:44 PM   #215
mknittle
mknittle's Avatar
I like that style light. I want to run the ones with blue dots.
Mark
My GMC build.
mknittle is offline
Old 11-11-2011, 07:44 PM   #216
Daze57
Daze57's Avatar
police here hate blue dots !
Daze57 is offline
Old 11-12-2011, 09:53 PM   #217
Russell Ashley
Russell Ashley's Avatar
I installed a pair of courtesy lights that come on when the door is opened, and finished up my hazard flashers. I used after market tag lights for the lights, and door switches that I picked out of the NAPA catalog. The hazard switch is mounted where the choke would normally be. It's a Ford switch that I got off of EBay, but I have a chrome Chevy style knob ordered to make it look better..
Russell Ashley is offline
Old 11-13-2011, 10:18 PM   #218
Purec4
Purec4's Avatar
Did some minor fiberglassing of holes in the inner rocker panels, for lack of knowing what to call them. Hope to smooth them out tomorrow with a little bondo. Got a couple of interested buyers who want to come see it this week. Try and do some little things to make it look better and if they don't take it, I got a little bit more off of the to do list. And patched a whole in the lower cowl side where it rolls under. Good therapy if nothing else
Purec4 is offline
Old 11-13-2011, 10:56 PM   #219
OrrieG
OrrieG's Avatar
Cleaned up a bunch of small parts for paint. Measured for the gas tank fill pipe.
OrrieG is offline
Old 11-13-2011, 11:39 PM   #220
LEEVON
Moderator
LEEVON's Avatar
Stared longingly at it, then finished bringing in the groceries.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline
Old 11-14-2011, 09:26 AM   #221
handyhands
Picked up a 51 chevy Sunday evening, it 's setting on the trail out back and will unload it today. S10 swap. Frame painted, front suspension waiting to be blasted, need gasket kit to put the motor back together( also painted ). Got my rally wheels last week.
handyhands is offline
Old 11-14-2011, 11:47 AM   #222
Dan in Pasadena
Originally Posted by handyhands View Post
Picked up a 51 chevy Sunday evening, it 's setting on the trail out back and will unload it today....
You realize we don't believe you without PICTURES, right?
Old 11-14-2011, 01:48 PM   #223
FFredo
Just got off the phone with "fenders n' more" out of Santa Fe Springs CA.
http://fendersnmore.com/
Orered the custom fenders for the flatbed 59.
I tried finding ready made fenders but no one had what I needed so I went custom made.
If anyone needs a AMERICAN MADE FENDER I recomend these guys. Great customer service, great turn around time and not too bad price wise. Mine will come in at around $100.00 shipped! I should see them around the end of the week or early next week.
FFredo is offline
Old 11-14-2011, 02:50 PM   #224
hsdropout
In memory of all Vetrans........Got the cab set on chassis over the weekend to check motor/tranny location. Will probably lift the tail of the tranny up about an inch, other wise it sits pretty good. It has been a little over a year since I started ripping it apart. Some progress but long way to go. Hoping to start on motor this winter.
hsdropout is offline
Old 11-14-2011, 03:05 PM   #225
BShort
Picked up some wheels from FFredo, installed my front turn signals, wire-loomed under the hood, cleaned up the garage a little in preparation for the under bed gas tank installation coming up.
Nice meeting you FFredo, super nice guy and you were very welcoming. It's great to meet forum members and build friendships.
BShort is offline
Closed Thread
