Old 11-08-2011, 07:06 PM   #1
bigblok77
Which 6cyl is it?
how do you tell a 250 from a 230(235)?
just curious, stepdad is giving me his running 6 cyl he doesnt know which it is either...
thanks
WES
Wes
1965 chevy c-10 short fleet,http://www.67-72chevytrucks.com/vboa...d.php?t=474572
1999 dodge swb 3.9 DD
2002 chevy 2500 hd 6.0 4x4 (ol' ladys truck)
bigblok77 is offline   Reply With Quote
Old 11-08-2011, 09:03 PM   #2
rockdogg2020
Re: Which 6cyl is it?
If im not mistaken, the difference between the 230/250 is the stroke (crank). They use the same block and have the same bore. You could check the casting number on the crank. I have the same problem and i still havent found an easier way to tell the difference. But if it is a 230, i hear you can convert it to a 250.
rockdogg2020 is offline   Reply With Quote
Old 11-09-2011, 11:12 AM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Which 6cyl is it?
Chevy Six Cylinder Casting Numbers
http://67-72chevytrucks.com/vboard/s...d.php?t=356268
Casting Number Lookup Tool
Chevy Six Cylinder Casting Numbers can usually be found just above the starter on the "passenger side" of the block.
http://www.adchevy.com/tools/castinglookup/
Second generation
1936–1962 Chevrolet Blue Flame six (also used in some GMC Truck models)
http://en.wikipedia.org/wiki/Chevrol...ond_generation
1962–1990s Chevrolet "Third generation" six
http://en.wikipedia.org/wiki/Chevrol...ird_generation
Online engine resources (casting numbers, calculators, etc.)
http://67-72chevytrucks.com/vboard/s...d.php?t=382583
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 11-09-2011, 03:26 PM   #4
awbrown
distributor position is the dead giveaway , 230 , 250 292 the distributor is toward the front 216,235,261 is more towards the center .. also the belhousing pattern is different ,235 is directly on the back of the block , the 250 is wider at the rear and the same pattern as a 350 chevy ...
awbrown is offline   Reply With Quote
Old 11-10-2011, 09:49 AM   #5
bigblok77
thanks guys, I'm going to take a look at it today, Ill post some pics and get the casting #s
Wes
Old 11-10-2011, 10:23 AM   #6
68gmsee
Active Member
68gmsee's Avatar
For further reading... I found this site discussing a similar question.
http://www.webrodder.com/phpBB3/view...e7c0f1aa92b5e6
68gmsee is offline   Reply With Quote
