86 c10 rearend ?
Hey guys I have a 86 c10 gmc step side 4.3 4 speed with granny first gear. My qestion is what gears do I have in the rearend and will my current bell housing fit a 350 engine?
Posted via Mobile Device |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: 86 c10 rearend ?
No way of knowing the gear ratio short of checking it personally. You'll have to either jack it up and spin the wheels or remove the cover and see the gear tooth count.
Bellhousing fits a small block fine with no mods.
What about the flywheel will it fit on a 350 too?
The bellhousing from the 4.3 will bolt to any SBC, the flywheel should be from the later one piece rear main seal design. I am not sure if the balance on the 4.3 in 1986 and later is the same as the 350 after 1986. The flywheel will not fit any 1985 or earlier two piece rear main seal SBC, bolt pattern is different.
PS 400 SBC will not interchange with the 4.3 flywheel under any case.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
#5 | |
Insert Witty Text Here
Slonaker |
#6 | ||
Like TXFirefighter says: no way of knowing without checkin' em out. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-10-2011 at 08:28 AM. |
Gentleman Jim Driver
My 85 with the 4.3 and 4 speed has 2.73 gears.... Not for long though...
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#8 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Here's a copy of the actual powertrain chart, so that we are all on the same page:
