Old 11-09-2011, 11:38 AM   #2176
7dee2
7dee2's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Kool, so the colored thingies live another day.. High tech s**t is what I luv about this hobby!
My eye is now avoiding looking at the master cylinder reservoir. Avert your eyes it will be so #1!
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 11-09-2011, 08:55 PM   #2177
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
It's looking great Drew! The wiring mess will all be hidden soon.
Ryan
1969 Chevy milk truck
Old 11-10-2011, 02:21 AM   #2178
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
One day I may need some of this.
Trying to fit the overflow bottle and have clearance for the hood hinge.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 11-10-2011, 02:25 AM   #2179
71Sleeper
71Sleeper's Avatar
Wow! it is getting alittle tight under the hood now. But I know you will make it all fit some how.
71Sleeper is offline   Reply With Quote
Old 11-10-2011, 05:10 AM   #2180
72shortstep
lovin' the lowcountry
72shortstep's Avatar
Any way to use an overflow bottle from another vehicle from the JY? Might be able to find the shape you need?
Chris
29461
72 SWB stepside
71 SWB stepside
DRIVE IT LIKE YOU STOLE IT!
72shortstep is offline   Reply With Quote
Old 11-10-2011, 07:06 AM   #2181
mcmlxix
Collector of Projects
mcmlxix's Avatar
looks like it calls for a custom welded stainless overflow catch that fills in the some open space on the fender well ....
... since everything else is custom .....
Rich
1972 K5 Blazer CST Click HERE
Old 11-10-2011, 10:02 AM   #2182
67cheby
67cheby
67cheby's Avatar
maybe a car overflow, like a late model impala or malibu...would be flatter ?
67cheby is offline   Reply With Quote
Old 11-10-2011, 12:39 PM   #2183
drewskiren
drewskiren's Avatar
It is just not working out with the factory airbox. The tubing is too short and the radiator bottle won't fit. I just ordered a new air intake kit that will allow me to relocate the filter and swap the overflow bottle into it's spot.
Drew
Old 11-10-2011, 12:42 PM   #2184
67cheby
67cheby
67cheby's Avatar
well that should fix that problem
Old 11-10-2011, 04:05 PM   #2185
7dee2
7dee2's Avatar
I think that is a great idea. Too bad you can't use the factory box, but the aftermarket unit should look pretty cool. Would a K&N filter attached right to the trottlebody fit or is that the kit you are referring to?
Brett
Old 11-11-2011, 01:29 AM   #2186
drewskiren
drewskiren's Avatar
On the trucks, the fan and radiator shroud come up too high to go straight on. It will be a 90 degree bend/tube setup.
Tonight I just worked on tidying up a bit with wires and grounding straps, checking and tightening bolts, etc. Nothing picture worthy.
Drew
Old 11-11-2011, 03:39 AM   #2187
dmack91
dmack91's Avatar
Everything on your build is worth a picture. Keep up the incredible work - you are an inspiration to all of us weekend wrenchers who only dream of having the ambition and ability to do what you have. Thanks.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 11-11-2011, 09:57 AM   #2188
drewskiren
drewskiren's Avatar
Thanks, but I think you are talking about Bruce and his build "Its Just A Pickup". THAT man has some skills and his work is definitely picture worthy.
Drew
Old 11-11-2011, 05:48 PM   #2189
drewskiren
drewskiren's Avatar
I've done a little gas cap sleuthing and figured out what a "vented gas cap" is and how it works. Everyone else may already know, but after disassembling it I realize that there is a one way check valve which allows air to be drawn in (to relieve the vacuum pressure of emptying the tank through using up the gas).
This valve will not allow fumes to be vented out into the air. It will be a piece of cake for me to just remove the check valve and dab some sealant in the air holes to keep any air from coming or going. My question is though, do I want to do this? Does a new truck cap completely seal or does it also let air in to relieve vacuum pressure just like the old one? I could try it unmodified first and see what happens, but now I am curious. Who's got an answer?
Drew
Old 11-11-2011, 07:12 PM   #2190
hgs_notes
GEARHEAD
hgs_notes's Avatar
Original tanks are vented directly in a few spots. Including a vent line on the filler tube. Cap is not vented. New stuff is different though and you can get check engine lights if the gas cap is left off.
hgs_notes is offline   Reply With Quote
Old 11-11-2011, 08:20 PM   #2191
drewskiren
drewskiren's Avatar
I needed to fuse my air ride system and was going to use a crummy inline fuse until I started poking around in my new fuse box and found an open slot for a 30 amp Maxi fuse. I went to an audio supplier and got the correct slot connector and tied it all in through the back of the fuse box. A ground to the body and air ride is ready to go!
Drew
Old 11-11-2011, 08:36 PM   #2192
JDeere550
JDeere550's Avatar
shooo awwweessshhhummmmmmmm!
1970 C/20 4x4, 350, sm465, np205(She tipped over... total rebuild from the frame up!)
ya gotta keep on keepin' on,
Life's a garden, dig it!
JDeere550 is offline   Reply With Quote
Old 11-11-2011, 08:41 PM   #2193
notsolo
notsolo's Avatar
Hey Drew May be there is some useful info here, Hope that helps http://www.aa1car.com/library/returnless_efi.htm
notsolo is offline   Reply With Quote
Old 11-12-2011, 01:56 AM   #2194
drewskiren
drewskiren's Avatar
My rad, rad. cover is looking good, almost factory. I may be needing door latches and a seat pretty soon. Oh, and brakes too.
Drew
Old 11-12-2011, 02:02 AM   #2195
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I love it!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 11-12-2011, 02:50 AM   #2196
VA72C10
VA72C10
VA72C10's Avatar
That looks great! Definitely the right choice painting it to match the rad support
Old 11-12-2011, 10:36 AM   #2197
oldman3
oldman3's Avatar
Sweeeet.....Jim
oldman3 is offline   Reply With Quote
Old 11-12-2011, 10:37 AM   #2198
sboris
sboris's Avatar
Things really look as though they belong. I love how your taking your time
to make sure things are done right. Did I say taking your time????
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 11-12-2011, 05:59 PM   #2199
drewskiren
drewskiren's Avatar
Drew
Old 11-12-2011, 06:26 PM   #2200
67cheby
67cheby
67cheby's Avatar
Awesome
