Old 11-10-2011, 11:47 AM   #26
Mr. 250r
Mr. 250r's Avatar
Re: Axle Options
Basically what mcm said but mine was 800$ I wasn't sure I over paid but it seems I didn't mine was 100% complete as well and my 86 D60 was 850$ with matching rear axle, everything I got all had 4.10s to match my stock gears which is what you'll find it most 3/4 tons or 3.73s
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold
2003 1500 Silverado - Selling
2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LB SRW
Mr. 250r is offline   Reply With Quote
Old 11-10-2011, 12:25 PM   #27
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Axle Options
Originally Posted by wade_ab View Post
sounds good, thanks
ill have to start searching the bone yards. what gear ratio would most likely be in the 3/4 ton fronts?
If you stick with 3/4 ton, just upgrade the outer assembly as described in the link above... If there's nothing wrong with the front axle, you would be taking a chance on an unknown part if you swap in another... I would guess 3.73 is common for the 3/4 ton... if you want to pay the $$ for a D60, I think the 4.10 is more common. Average asking price is $1000...
Rich
1972 K5 Blazer CST Click HERE
Old 11-10-2011, 12:53 PM   #28
Tex_50613
Redneck Customs Bumpers, IA
Tex_50613's Avatar
Re: Axle Options
any i've gotten have been from 3/4t with the sm465 and have been 4:10 or 4:11 ratio
Overkill is under rated, Redneck Customs Truck Club Hudson, IA
"Clifford" 83 Chevy K20 4x4, Mudder 7" lift rolling 44's
"Basterd Child" 86 Chevy K30 4x4 crue cab Dule, 7.3l international WIP
'00 ex-cab Silverado 4x4 DD
I hate red trucks but you can't tell by looking at what I own
Tex_50613 is offline   Reply With Quote
Old 11-10-2011, 04:22 PM   #29
snj8198
snj8198's Avatar
Re: Axle Options
here is a quote from the article:
GM Hot cam, which had a 112-degree LSA and a lopey idle. It turned out that the first step up from stock-Crane's PN 1449551 with 210/218-degree duration at 0.050-inch tappet lift-was a real torque monster, churning out more peak and average lb-ft than any other cam tested.
Read more: http://www.hotrod.com/techarticles/e...#ixzz1dFVPeNKZ
after they did all their "mild mods" they were getting over 500 hp
210/218@.050 isn't so scary for towing in a 6.0L. Good read.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 11-10-2011, 04:26 PM   #30
wade_ab
wade_ab's Avatar
Re: Axle Options
yeah thats a good article, I think im going to try and follow it when the time comes. save me some headache and money being that they tested everything on the dyno and suggest the best part to slap on.
69 k10 - In pieces
wade_ab is offline   Reply With Quote
12 bolt, 14 bolt, axle, dana 44, dana 60
