Old 11-11-2011, 08:40 PM   #1
48richard
48richard's Avatar
Fuel Gauge Help
I took out my instrument cluster this afternoon to install and connect up my clock. After I put it back, when I turned on the ignition the fuel gauge needle moved round to the 4 o'clock position and remains there. It has always worked correctly until now. Everything else in the cluster works (including the clock).
Any ideas?
Thanks,
Richard
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 11-11-2011, 09:35 PM   #2
Devil Pup
Devil Pup's Avatar
Re: Fuel Gauge Help
Your gauge is grounding out somewhere. that will cause it to always read full like that. Considering you had the cluster out i would check there first and if that doesn't turn up trace it all the way to the sending unit. Its shorting somewhere.
Devil Pup is offline   Reply With Quote
Old 11-12-2011, 01:01 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Fuel Gauge Help
You have lost the connection between the sending unit and the fuel gauge. It is a tan wire and runs from the center terminal of the sender to the fuse panel and from there to the cluster plug at the no.4 pin. If you ground the fuel tank sender wire the gauge should go to empty. The same should happen if you ground the fuel terminal on the fuse panel.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-12-2011, 01:30 AM   #4
Devil Pup
Devil Pup's Avatar
Re: Fuel Gauge Help
If u ground a fuel gauge it will ping full. You r correct he has lost signal, that wire is grounding causing it to read past full. If u find where it is "shorting persay" when u move it from where it's grounding the gauge will respond and go back to empty.
Old 11-12-2011, 01:45 AM   #5
dmack91
dmack91's Avatar
Re: Fuel Gauge Help
No offense to Devilpup, but go with Vettevet's advice. He has helped me and others through similar problems many, many times.
Open circuit causes the gauge to go to 3 o'clock, grounded makes it go to 9 o'clock.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 11-12-2011, 11:22 AM   #6
Devil Pup
Devil Pup's Avatar
Re: Fuel Gauge Help
No offense takin. Everyone can be wrong or backwards once in a while. Just trying to help out. Let us kno what u find out and good luck.
Old 11-12-2011, 07:54 PM   #7
48richard
48richard's Avatar
Re: Fuel Gauge Help
You guys are awesome - thanks. Turns out that when I inserted the cluster plug, the little flap on the printed circuit for pin #4 got pushed aside enough so that there was no contact, even though it looked to be OK. When I put it together properly, problem solved.
Thanks again,
Richard
Old 11-12-2011, 08:20 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Fuel Gauge Help
The funny thing is the temperature gauge works just the opposite. When you ground the sender the temp gauge will go to full hot. I have to think about which one does what whenever somebody needs to check the gauges. I posted it wrong just the other day. Maybe you were thinking about the temperature gauge.
The main thing is that you were trying to help and that's never a bad thing. VV
VetteVet
Old 11-13-2011, 06:10 PM   #9
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Fuel Gauge Help
looks like I'll be using this one shortly Thanks for everybody's input
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
