Carb shock vacum
Re: Carb shock vacum
I don't think so. The choke on your Q-Jet needs hot air from a tube that used to go where your egr valve is now. Others will help you out soon.
Active Member
![]() Join Date: Jul 2007
Neither will work. Choke needs heat and egr uses carb/ported engine vacuum.
