Grandpa in the rustmobile...
Re: The Blue Goose
not sure hubscrub-
The entire door just needs to move toward the rear of the truck about a 1/4" the door/fender pretty much touch
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Junk Yartist
Re: The Blue Goose
Got some motor cycle ratchet straps? I have a red-neck trick that works...
You need ratchet straps, and something that is the thickness of the gaps you want. -Take off your fenders -instert your shims between the doors and body -ratchet strap the doors through the windows and where ever you can to keep the doors from moving -loosen the hinge bolts -adjust the door by using the ratchet straps -tighten down the hinges -put your fenders back on -take off the ratchet straps if you want to open the doors
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#3 | |
Lucky Teter at the wheel
Re: The Blue Goose
To get the fender off, take off the cowl panel to find the 2 upper fender bolts, unbolt the hood hinge, one huge bolt in the fender liner at the rear, one bolt at the bottom of the fender at the rocker, and a few at the bottom edge of the radiator support attaching the fender liner, and 2 near the back of the head light on the rad support. Sounds like about 20 minutes, tops.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
Re: The Blue Goose
drew is spot on but i dont think you want to take the fender off so take a pencil or sharpie and outline around the hinges where they mount to the door then take the hing to door bolts off (6) then once the door is off and its just hinges on the cab take a pencil or sharpie and outline around the hinges then loosen the bolts (6) and slide it back how ever much the door needs to come back then check to see if its equal in the horizontal lines above and below the hinge and tighten then brong the door back and put the hinges directly in the outlines on the door. tighten up WHEN DOOR IS OFF MAKE SURE TO PUT TRIM ON!!!!!!!!! putting the clip on right behind the fender will suck because there is no way possible to tighten the little nut behind the door.
