Old 11-15-2011, 12:09 AM   #301
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: 1964 Suburban Pics
Originally Posted by protrash64 View Post
Cheap Summit ministarter was manufactured wrong and ate my new flexplate.
Don't tell me that (ears plugged) lalalalalalalala I still have to check the engaugment to the flexplate on mine.
Alan's Classic is offline   Reply With Quote
Old 11-15-2011, 12:28 AM   #302
protrash64
Resistance is Futile
protrash64's Avatar
I can tell you the specs; max distance from flywheel is .100'' per their instructions. Mine was at .250'' (quarter inch). No way to adjust unless its disassembled and the billet block is milled down .15''. Dont use it unless you can have it milled. If you need a small starter use something from a '95 smallblock; they are tiny. My 454 starter wieghs 10lbs!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-26-2011, 08:33 PM   #303
protrash64
protrash64's Avatar
Got the 'burb all back together and have driven it around quite a bit today. I also cleaned the drip rail and resealed it as all the seam sealer was gone and its a little rusty up there.
My starter works perfectly, brakes seem to be holding together and the trans is shifting so life is good!! Put a new serpentine belt on the 454 just for fun!!
Just shot a pic with all three in the driveway.....now I can finally get to the '64 shorty..........
Old 11-26-2011, 09:30 PM   #304
daverod
SSN 706
daverod's Avatar
Sucks about the flex plate. Just somthing else for me to worry about. Cool picture.
daverod is offline   Reply With Quote
Old 11-26-2011, 10:01 PM   #305
protrash64
protrash64's Avatar
Thanks Dave......I did not feel like re-doing the flex plate but it turned out not being horrible. I spend time to get it right the first time and that starter was out of my control. However, I did learn about the stock starters from the newer engines and that was good. They are tiny and are geared low too.
Old 01-02-2012, 05:59 AM   #306
C@rnut001
i know that you haven't posted on this for a while, but I had to say that I think you have an awesome truck here and I loved reading about your updates and improvements to it. I also love the fact that you put the big block in it! Hope you are able to cruise around in it this year a lot! Keep up the great work on your trucks!
C@rnut001 is offline   Reply With Quote
Old 01-02-2012, 08:52 AM   #307
protrash64
protrash64's Avatar
Thanx dude!! I will have an update on this in awhile as I will be painting the roof. Just need to do the compressor break in and get to the prep; and decide a color.
Old 01-02-2012, 09:07 AM   #308
northern 85
northern 85's Avatar
Cool pic,looks like they they want to get in the garage for more wrenching Nice Work
northern 85 is offline   Reply With Quote
Old 01-02-2012, 09:42 AM   #309
darkhorse970
darkhorse970's Avatar
I love this pic! It is really cool to see all 3 grouped together.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 01-02-2012, 10:06 AM   #310
protrash64
protrash64's Avatar
Thanx man!! I forgot I posted this on here until Cornut brought up the thread. I had cleared out the 'burb to work in the garage and saw them lined up like this; thought 'that would be a good pic' and shot it!!!
Old 01-02-2012, 10:07 AM   #311
protrash64
protrash64's Avatar
I've done enough wrenching!! I want to drive them! I will be doing some sanding, however.
Old 01-08-2012, 11:40 PM   #312
protrash64
protrash64's Avatar
Started sanding the roof of the 'burb. Damn it's huge!!! I picked up some Werner aluminium platforms to stand on and reach the top of the truck. I looked into some new (old) body parts and have come up with a plan for prime/paint. I am working on this truck, and as I paint various parts, I will also get parts ready off the '64 shorty and paint them as well. Two pronged assault!! Here's a pic of the white dust.........
Old 01-09-2012, 01:02 AM   #313
mosesburb
I had a V-8
mosesburb's Avatar
Looks like progress man!! I hate sanding. I spent my afternoon welding rivet holes and sanding paint on some panels I have here. I'd much rather be doing fab work instead.
Those Werner platforms are the cat's ass!! I bought a couple of those on sale a few years ago (right after I finished my Suburban as a matter of fact). I have used those for so many things and recommend them to everybody.
Looks good man!!
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 01-09-2012, 07:09 AM   #314
TimE
Hey Y'all!!
TimE's Avatar
Now I see where the dust on your monitor really came from...
Lookin good!!
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 01-09-2012, 01:46 PM   #315
protrash64
protrash64's Avatar
Looks good man!!
Thanx Nick. I have had to get fired up to sand but I need to take advantage of the weather. 5 months until the heat!!! I try to crank up some tunes and then just zone out and keep my arm moving.
Old 01-09-2012, 09:34 PM   #316
babylonflyer
babylonflyer's Avatar
I need more pics!!
babylonflyer is offline   Reply With Quote
Old 01-15-2012, 12:10 AM   #317
protrash64
protrash64's Avatar
Ok, sanding is boring but I did make it thru quite a bit and have more in my future. Wiped the top down for some small dings and scratches; need to sand. I have been rounding up parts for the 'burb and got a new grill support. Spent most of today cleaning it up and knocking a few dents out of it...ended by rust treating the back of the panel. Drivers side fender is going to get a patch panel and dug out my pass fender. I was going to make this thing live again but have decided on a repop with this one donating the grill section. I think there is one thing I cant repair and dont want to put more time into it. I have enough to do on the whole truck.
Also picked up a new column to rebuild so I can get rid of the 73+ tilt that I hate in there. More updates tomorrow.
Old 01-15-2012, 11:49 AM   #318
Dinos63
chevy only
Dinos63's Avatar
nice work jeff. i have changed those flex plates too and its sucks doing it on jacks stands..... heck its sucks also doing on a lift cool pics you got some nice c10s
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 01-15-2012, 12:01 PM   #319
protrash64
protrash64's Avatar
No doubt!! Especially when you think its all good and taken care of for the long haul.
Old 01-16-2012, 12:10 AM   #320
protrash64
protrash64's Avatar
Made some more progress today....took off the drivers side fender and all the bolts came out!! Had to grind thru the front and hit the bottom bolt with lube but was amazed when it finally let go. 3lbs of dirt fell out, too. This one will get a patch panel and needs some work on the brace; not much. Also found some marks on the cowl vent cover; factory marks?? Dont know but I dont think that fender had been off before. Everything is in good shape with the exception of a hacked up spot from a speaker in the kick panel. Also pulled off the passenger fender. Musta weighed 40lbs with all the bondo!! It was done in the 'cave it and pave it' style of bodywork. Time to make some pieces and soon start welding.
Old 01-16-2012, 08:47 PM   #321
protrash64
protrash64's Avatar
A little more progress today. Took the drivers side fender out to give it a workover. I washed it and degreased it first. Ground out the paint and found it wasnt too rotten after all. It had been filled with bondo down in the brace area we all know. I was happy that I could section out a piece of the patch panel and not have to weld all across the fender. I need to fix the brace as its crusty but it will stay.
I also decided to put the '64 C-10 emblems back on the truck. I had one and picked up another off a '64 'burb btw. Also hiding in the box is a new 'counterfit' pass fender. Looks Im going to be busy next weekend, too.
Anyone know how to clean paint overspray off chrome?? One emblem has some and Id like to shine it up.
Old 01-16-2012, 08:48 PM   #322
protrash64
protrash64's Avatar
New fender.........
Old 01-16-2012, 09:06 PM   #323
aggie91
I'm just glad to be here!
aggie91's Avatar
Try a rag soaked in laquer thinner to remove the paint over spray.
I'm going to have go back and catch up on this one...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-16-2012, 09:09 PM   #324
protrash64
protrash64's Avatar
Cool; I'll try it. I looked at my aluminum polish and it said not to use it on chrome. Thought about steel wool, too. Just dont want to scratch it up too badly.
Old 01-17-2012, 12:13 AM   #325
protrash64
protrash64's Avatar
Didnt have any thinner so after cyphering for a spell, I decided to use some rubbing compound and it worked. The chrome is still good so I used a razor knife to scrape the paint off like cleaning glass. Then I just rubbed the crap out of them and they polished up nicely.
