Old 11-15-2011, 03:40 PM   #1
hotroddan
hood mounting with no inner fenders???
so the inner fenders on my truck a rotted pretty bad and are really expensive new. so seeing as im lowering it and running big rims i was just going to take them out but the hood hinges off the inner fenders. what did you guys with no inner fenders use to hinge your hood? pics would be great
hotroddan is offline   Reply With Quote
Old 11-15-2011, 04:17 PM   #2
Revoh
Revoh's Avatar
Re: hood mounting with no inner fenders???
I think markeb01 might run without inner fenders. He usually monitors this section pretty closely, but you might PM him.
1963 C-10
My car blog, for your reading pleasure.
Revoh is offline   Reply With Quote
Old 11-15-2011, 06:03 PM   #3
csa daddy
csa daddy's Avatar
yes this would be some good info
csa daddy is offline   Reply With Quote
Old 11-15-2011, 06:28 PM   #4
Clyde65
Clyde65's Avatar
Porterbuilt makes some hinges you might want.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-16-2011, 07:27 PM   #5
hotroddan
wow those porterbuilt ones are 265 im building on a budget. anyone have some pics of modified stock ones or a cheap diy set??
Old 11-16-2011, 08:12 PM   #6
64shortc10
64shortc10's Avatar
PORTERBUILT STREETRODS also makes a cheaper version that uses the stock hood hinge.
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 11-16-2011, 08:31 PM   #7
nhtc33d
Did someone say cheap? I got a set of stock firewall mounted hinges from a old dodge dump truck and modified them. It was pretty easy,just had to make firewall mounting area about 1" longer and then bent up some new hood mounting pads and done!!
nhtc33d is offline   Reply With Quote
Old 11-16-2011, 09:19 PM   #8
jimmydean
jimmydean's Avatar
Nate's hinges are worth every penny, though.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-16-2011, 09:42 PM   #9
joedoh
joedoh's Avatar
you always pay for quality, and porterbuilt is very high quality.
I will be using a buick forward tilt hood hinge like others on here have.
Old 11-16-2011, 10:22 PM   #10
dthela
dthela's Avatar
tons of inner fenders on ebay! what going to hold your outer fenders??????????????? (not to mention rad support and headlights.
dthela is offline   Reply With Quote
Old 11-17-2011, 10:09 AM   #11
hotroddan
Not saying the porterbulit are bad just at close to 300 bucks ill just get new inner fenders
