Old 11-15-2011, 09:16 PM   #1
1972RedNeck
1972RedNeck's Avatar
In Need Of Measurements
Could somebody give me the following measurements on a stock K20/K2500:
Ground to front front spring bolt
Ground to front rear spring bolt
From axle to top of fender well
I would appreciate if someone could give these measurements to me.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 11-16-2011, 12:18 AM   #2
dmack91
dmack91's Avatar
Re: In Need Of Measurements
Can't help you on the measurements. The problems you will run into is that the ground to spring measurements will be dependent on the tire size you are running, as well as the condition (sagging or not from age) and type (stock or lift) of springs you have.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 11-16-2011, 09:05 AM   #3
1972RedNeck
Very true. I forgot about that. I guess i just need the axle to the fender well.
As far a condition goes, I just want a rough estimate. Original stock springs will work fine.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 11-16-2011, 06:59 PM   #4
1972RedNeck
Nobody?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 11-16-2011, 08:44 PM   #5
JimKshortstep4x4
I can get you a measurement on a K-10 tomorrow if that will help.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-16-2011, 09:00 PM   #6
1972RedNeck
If it is stock it should be close enough.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 11-16-2011, 10:15 PM   #7
domeier
domeier's Avatar
I just took the lift off my K-10. Rear is 20" center of axle straight up to fender well. But... the front is 22". I guess the rear has a bit of a sag going on here.
domeier is offline   Reply With Quote
Old 11-16-2011, 10:26 PM   #8
1972RedNeck
Both stacks are GM springs though?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 11-17-2011, 08:55 PM   #9
JimKshortstep4x4
My 71 K-10 is 24" from the top of the axle straight up to the inner fender. It has stock springs in it, front and rear.
Here is a pic of it.
Jim
Old 11-17-2011, 09:03 PM   #10
1972RedNeck
Jim
So is that to the highest point in the inner fender?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 11-17-2011, 10:22 PM   #11
domeier
domeier's Avatar
Yeah, it's all GM, but... now you got me thinking, and I just figured out why my butt end is sitting two inches lower than the front after removing the lift: This truck started life as a 2wd. My rear springs must be for 2wd, the fronts are 4wd. I was trying to figure out how 6" of blocks in the back equaled a 4" lift, and now I know. Dangit man - I'm kicking myself right now. In order to raise the rear back up to level, I'll have to put 2" blocks on, and that means the U-bolts I just bought at NAPA for $18/ea... are instant junk.
Oh the pain, William... The pain!
Old 11-17-2011, 10:49 PM   #12
1972RedNeck
I think the springs were the same. I think that the mounts on the frame are different.
Key Word = Think
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 11-18-2011, 12:41 AM   #13
domeier
domeier's Avatar
Key Word = Think
I'm confused as hell now. I thought I had a 4wd frame... but now I don't know what I think I used to know. How do I find out?
Oh, and sorry for hijacking your thread. What was your question again?
