Re: AD steering column conversion
i installed a clip from a 81 malibu onto my 49 chevy truck. i cut the bottom of my steerin an used the malibu steering rod, it slid right on mine just like it was made to do that. i cut the bottom of the malibu steering housing an welded it to mine, i then took the bottom bearing out an slide the two steerin shafts together, i then welded an drilled the shaft an put a grade 8 bolt an put it all back together an u cant even tell that any thing was done, so i kept my old steerin column
I used a flange bearing that has set screws that I found on the internet, it has a 1/2" I'd which is the same as the shaft once you cut off the part that goes in the steering box, I cut mine long so I had room for adjusting, after I mocked it up the way I liked it I cut it so there was only a few inches coming out of the firewall, then ground a "D" into the inner shaft and put my joints on from there. Make sure you use or make something to attach the column to the floor as well.
Posted via Mobile Device |
