Gas door modification
Has anyone replaced the factory open design filler with a door type filler? If so are there any tips you have. I am replacing the fuel tank and would like to tackle this if its not too tough. Thanks
What?
Re: Gas door modification
I have seen a few on here.
The only one that comes to mind is Frizzle Fry's shortened and slammed burb build. http://67-72chevytrucks.com/vboard/s...239896&page=19 Check out the thread, and see if he covers doing that bit.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
It's been years since I did this but I got a door from the junk yard. I cut about 5 inches all the way around it and got the cable assembly also to open the door. I don't think I had to modify the filler tube. It fit behind the door.
Mine had a gas door on it when I bought it.....assumed it was factory...I did not see any signs of bodywork when I recently did the paint and body on the truck:
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) |
![]() Join Date: Aug 2005
Thanks for all the help everyone. You have some nice looking burbs/tahoe. I ended up at a junkyard and they are pulling an late 90's S-10 Blazer door area with all the other items neck, brackets etc. Hope to get to it next week. Should look better since I have everything shaved.
Tim240z how did you recess your taillights? That looks good.
I bought it like that....I wish I could figure out how it was done, so that I can undo it....I don't like it....makes the rear of the truck too flat....no relief to the eye....it even had steel tail light louvers that bolted on, and I really didn't like that....
Devil's in the Details
I did mine using a Chevy Van flap and fill tube that I cut from a wrecking yard. I went through the process in my build thread.
http://67-72chevytrucks.com/vboard/s...=397868&page=4 It starts on post 98, continues in 99 and finishes in post 101. ![]()
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
#10 | |
Love the paint dude.Been looking for some hot design for my panel. If don't mind I think we will take few ideas from yours and incorporate them into my colors ,bule with draker gray and some meganta and orange and yellow stripes around it. Kind of our funnycar colors toned down for street vehicle.Plus same colors as my new dragster it will be towing. |
#11 | |
Thanks for the kudo's. Here is a close up of the door. This thing had about 22 different paint tricks going on.
