Old 11-16-2011, 04:02 PM   #1
1963c-10
1963c-10's Avatar
Trying to locate factory steel wheels w/4 bumps on front for disc brake/ whubcap
Anybody know where to locate some of the factory steel poverty rims that have the bumps on the front to hold the dogdish hubcaps? They'll have 4 holes in the rim. I need some to do a disc brake conversion on a 63 and the rims were stock chevy/gmc from 74-up.
1964 Short bed trailer
Old 11-16-2011, 09:53 PM   #2
lilpoindexter
lilpoindexter's Avatar
Re: Trying to locate factory steel wheels w/4 bumps on front for disc brake/ whubcap
Any C10 or G10 van in the junkyard.
lilpoindexter is offline   Reply With Quote
Old 11-16-2011, 10:20 PM   #3
SCOTI
SCOTI's Avatar
Are you wanting the 5-lug wheels or 6-lugs?
The 5-lugs can be found under many 'plain' 71-87 GM trucks or suburbans that had factory full wheel hubcaps. The 6-lug models were the 'cheap' wheels on the 73-87 4wd's (blazers, burbs, & trucks). The 6-lug wheels are harder to find.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-17-2011, 09:36 AM   #4
1963c-10
1963c-10's Avatar
Looking for the 6 lug. Have two....but need at least 1 for a spare and would like 3 total. I have been through every yard within 45 min off here that I know of and can't locate any. Should be a common wheel.
Old 11-17-2011, 01:55 PM   #5
SCOTI
SCOTI's Avatar
Common then, but hard to find now.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-17-2011, 03:20 PM   #6
1963c-10
1963c-10's Avatar
Yeah...seems so. But like most of the stuff we want...just keep on looking. Its out there somewhere
