In Need Of Measurements
Could somebody give me the following measurements on a stock K20/K2500:
Ground to front front spring bolt Ground to front rear spring bolt From axle to top of fender well I would appreciate if someone could give these measurements to me. |
Re: In Need Of Measurements
Can't help you on the measurements. The problems you will run into is that the ground to spring measurements will be dependent on the tire size you are running, as well as the condition (sagging or not from age) and type (stock or lift) of springs you have.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#3 | |
As far a condition goes, I just want a rough estimate. Original stock springs will work fine. |
Nobody?
I can get you a measurement on a K-10 tomorrow if that will help.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
If it is stock it should be close enough.
I just took the lift off my K-10. Rear is 20" center of axle straight up to fender well. But... the front is 22". I guess the rear has a bit of a sag going on here.
Both stacks are GM springs though?
My 71 K-10 is 24" from the top of the axle straight up to the inner fender. It has stock springs in it, front and rear.
Here is a pic of it. Jim
So is that to the highest point in the inner fender?
Yeah, it's all GM, but... now you got me thinking, and I just figured out why my butt end is sitting two inches lower than the front after removing the lift: This truck started life as a 2wd. My rear springs must be for 2wd, the fronts are 4wd. I was trying to figure out how 6" of blocks in the back equaled a 4" lift, and now I know. Dangit man - I'm kicking myself right now. In order to raise the rear back up to level, I'll have to put 2" blocks on, and that means the U-bolts I just bought at NAPA for $18/ea... are instant junk.
Oh the pain, William... The pain! |
#12 | |
Key Word = Think |
#13 | |
Oh, and sorry for hijacking your thread. What was your question again? |
| Bookmarks |
