Old 11-18-2011, 12:35 AM   #1
erikog76
64 c10 pertronix kit ?
im dumping my points set up and switching to the pertronix kit 1162 a for a inline 6 250 what coil and wires should i get do i need hotter plugs and what about the resistor to the coil im running now would i still need it thanks fellas for any help
erikog76 is offline   Reply With Quote
Old 11-18-2011, 12:55 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 64 c10 pertronix kit ?
According to the attached Pertronix instructions it appears you keep the resistor if you already have one. I believe most people open the plugs up from .035 to .040 or .045 after installing either a Pertronix kit or HEI, but don’t normally change the heat range. I'd start with .040 and see how it behaves.
I installed one of these in my wife’s F250 about 10 years ago and it still works great.
http://www.pertronix.com/support/man...itor12vneg.pdf
