Old 11-16-2011, 09:38 AM   #1
Blue666
Rear Disc Brakes
Has anyone investigated using a factory GM rear disc assembly from a 99 to 07 Silverado 1500 in a 60 -66 truck?
Any good guess as to the width WMS to WMS & axle tube diameter?
What about just using the mounting plates, calipers & rotors & hoses?
How does the parking brake work on these rears?
Not a great picture but shows the parts & pieces.
Blue666 is offline   Reply With Quote
Old 11-16-2011, 01:09 PM   #2
jimmydean
jimmydean's Avatar
Re: Rear Disc Brakes
I would think that would be a great option. I went with a Caprice cop car rear because it was 5x5 like my front and was $50 on CL.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-16-2011, 01:32 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Looks like a decent option, whats the lug pattern on those? If you can swap the whole rear and keep the disc, great..but I don't know if it would be good for swapping just the brakes.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-16-2011, 01:42 PM   #4
ironcrossmike
ironcrossmike's Avatar
The parking brake is a "mini" drum type setup with 1 long shoe. I'm not sure on the width, but I would bet is quite a bit wider than your stocker.
ironcrossmike is offline   Reply With Quote
Old 11-17-2011, 01:40 AM   #5
Captainfab
60-66 Nut
Those newer rear ends are about 3-3.5" wider than the '63 to early '70 rear ends. As ironcrossmike said, they use a shoe assembly inside the rotor for the e-brake. The brake assemblies will not bolt onto a truck 12 bolt, without a good amount of modification.
If you're looking for a 6 lug rear disc conversion, I offer this one here
http://www.67-72chevytrucks.com/vboa...d.php?t=445599
I do have another 6 lug bracket that will work with 15" wheels, but I have not posted the for sale thread yet.
Old 11-17-2011, 01:57 AM   #6
Rich 5150 69
Rich 5150 69's Avatar
I book marked this Captain...for the 15 inch..cool
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 11-17-2011, 05:16 AM   #7
Blue666
I am looking at doing a gear change (4.11 to 3.42), add posi & add rear disc all in one easy low cost package. I am already running 17" wheels from a 2001 Suburban with 2" spacers on each side.
I have been watching these on CL & they seem to go as low as $200, generally $3-400. This rear seems to much easier to find than the F-body, Caprice or S-10 ZR-2 rear.
I still need to get a better handle on the overall width but I'm thinking that with some grinder time & extra set of saddles, this could be the correct asnwer for me.
Thanks everyone for your responses.
Old 11-17-2011, 05:06 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
I've seen one truck that had this rear axle. I didnt ask much about it but the guy said the biggest problem was the width. I've considered this too, but would probably change the studs to have the same SAE thread type front and rear.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-18-2011, 01:13 AM   #9
Captainfab
60-66 Nut
Rich, I got them posted up here...
http://www.67-72chevytrucks.com/vboa...22#post5016222
