I have a ford 9" rear end out of a 70' ford truck. And need to know where I can get a set of saddle's for it to go in my 67'? Also what is the highest gear I can get for it? And what should I set the pinion angle?
Keepin an eye out
For the saddles check here... http://www.earlyclassic.com/catalogpg23.html
i think the highest gear you can get for the 9" ford is a 2.08 to 1
I think the the pinion angle should be within 3 Deg.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Do you know where I can get a 3:07 gear or something close to it. I have a good 3:50 gear if anybody wants to trade. Thanks
Fabricate till you "puke"
You should be able to get a 3.00, or a 3.25 gear for the 9". most common in the cars was a 2.75 gear(mid to late 70s). On the pinion angle......with the truck on the wheels, check the trans angle.....if its 4 degrees down (example), set the pinion 4 degrees up. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 08-25-2003 at 05:39 PM. |
for the gearset check out ebay there's always a bunch and if you don't want a posi there real cheap for the whole third member
gears trade?
I have a 2.75 I believe, I will have to confirm it but i would trade!
What spline is it 28 or 30?
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
i have a 28 spline 2.75 that i'll never use
68 short step, 406/700r4, 9" w/discs. |
