Old 11-16-2011, 08:18 PM   #1
TIM86
TIM86's Avatar
Correct spacers needed????
Im looking to put some rims on my 86 silverado (5x5). Here are the specs.
Bolt Pattern: 5x120
Center Bore: 67
Hardware:14x1.50 Lug
Offset:
Front: 30-40mm
Rear: 30-45mm
Can anyone recomend the correct spacers and possibly a brand?
TIM86 is offline   Reply With Quote
Old 11-16-2011, 08:33 PM   #2
Pop's C-10
Pop's C-10's Avatar
Re: Correct spacers needed????
5x120mm wheels would not work...they need to be 5x127mm=5x5
Or are you asking about adpters(to change bolt pattern)
Or spacers to move them out some?
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 11-16-2011, 08:34 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Offset means nothing unless you know the rim width.
Keith
Convert to disc brakes.
Old 11-16-2011, 08:36 PM   #4
lolife99
lolife99's Avatar
Here's a good chart:
Keith
Old 11-16-2011, 08:46 PM   #5
TIM86
TIM86's Avatar
Sorry I should have done a better job wording it. I need adapters with the correct back spacing.
Old 11-16-2011, 08:50 PM   #6
lolife99
lolife99's Avatar
I'm having a hard time understanding any of your questions.
1) what size wheels?
2) exact offset?
30-40 mm is a range.
It's either 30 mm or 40 mm. Not both.
3)Is your truck stock height or lowered?
How low?
Keith
Old 11-16-2011, 08:54 PM   #7
lolife99
lolife99's Avatar
Adapters are sold by width and bolt pattern.
1" wide.
1.5" wide.
2" wide.
2.5" wide.
Keith
Old 11-16-2011, 09:42 PM   #8
TIM86
TIM86's Avatar
Ok guys sorry about that been a long day and I wasnt paying attention to the original specs posted. Here is what I have:
5x5 lug pattern
2.5" drop upfront
2 leaf springs removed
Rims I want to put on:
5x120mm pattern
20 x 8" / (front) P245/45ZR20 (front) +35mm offset
20 x 9" / (rear) P275/40ZR20 (rear) +40 offset
Old 11-17-2011, 03:08 PM   #9
TIM86
TIM86's Avatar
Anyone?
Old 11-17-2011, 06:32 PM   #10
lolife99
lolife99's Avatar
Anyone?
20 x 8" / (front) P245/45ZR20 (front) +35mm offset equals an approximate 5-7/8" Backspace.
20 x 9" / (rear) P275/40ZR20 (rear) +40 offset equal an approximate 7" back space.
That's alot of backspacing on wheels for these old trucks.
I would think a 1" adapter for the front wheels and a 2" adapter for the rear wheels.
The best way to measure would be to "mock up" the wheels and measure how much they need to move outward.
Keith
Old 11-18-2011, 12:43 PM   #11
TIM86
TIM86's Avatar
Great thanks for the info. Will try to figure it out this weekend.
