Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-18-2011, 04:20 PM   #10
Super73
Super73's Avatar
Re: Trailing arms cross member fliped?
Hotchkis,
Just curious, why didn't you add more adjustability like my home made bracket has? (both up and down)
One more thought, the shim you are providing with the kit, I'd assume this only corrects pinion angle for one set of holes? Or do you provide multiple shims?
My measuring/testing showed that for every 1" of movement at the LCA mounting point, an additional 1* of shim was required. Just curious. But you guys probably already knew that a one shim for all adjustments wouldn't work to correct pinion angle.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
