Old 11-19-2011, 05:59 PM   #1
kcfirstbuild
Hard time removing bed bolts
I'm trying to disassemble my 68 fleet side box. I have read you can use an impact and tighten them up till they break. I tried that but the carriage box spins. I tried it a couple times. I have some PB blaster soaking on them for the time.
Any other advice ?
I'm going to try a nut cracking tool for the ones i can reach.
kcfirstbuild is offline   Reply With Quote
Old 11-19-2011, 06:07 PM   #2
FLcustom10
Re: Hard time removing bed bolts
I used a dremel tool to cut one that I couldn't break loose.
FLcustom10 is offline   Reply With Quote
Old 11-19-2011, 06:12 PM   #3
kcfirstbuild
ok will try that next !
Old 11-19-2011, 06:28 PM   #4
red69ss
Burnouts are therapeutic
red69ss's Avatar
I center punched them , then step drilled them till the heads came off from the top. deffinently the easiest way I've found to remove them , its probaly easier if you don't try to loosen them first, but still may be effective.
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 11-19-2011, 07:44 PM   #5
redbaron69
redbaron69's Avatar
you can also try grinding a slot in them, and hold with a screwdriver. but if they are really rusty i would drill like mentioned above.
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 11-19-2011, 07:56 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Definitely cut them, before you ruin the "square hole" in the bed floor.
New bed bolts are a lot cheaper than repairing the bed floor.
Keith
Convert to disc brakes.
Old 11-19-2011, 08:42 PM   #7
Dano69c10
Dano69c10's Avatar
The easiest way I found to remove frozen bed bolts are with a 4" or 3" cutting wheel.
I crawl underneath and cut vertically through the nut and bolt. Sometimes you only have to cut halfway through and the nut will come off with a wrench or socket. This prevents you from messing up your bed.
If you're good at cutting, you can cut through the nut it will split off the bolt.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 11-19-2011, 08:54 PM   #8
72lb4x4
Sorry, you already tried my suggestion. I gotta work on my reading comprehension!
72lb4x4 is offline   Reply With Quote
Old 11-19-2011, 09:12 PM   #9
57larry
hot wrench is the way to go
57larry is offline   Reply With Quote
Old 11-20-2011, 12:26 AM   #10
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
I vote for the gas ax. Never met a bolt yet that I couldn't get out with it
Mike
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 11-20-2011, 09:14 AM   #11
cdowns
cdowns's Avatar
my 3" cutoff wheel makes short work of removing bolts
Old 11-20-2011, 03:08 PM   #12
ChumBucket
Wrenches? Cut-off wheels?...the best method - PLASMA CUTTER, OH YEA!! Best tool ever invented.
ChumBucket is offline   Reply With Quote
Old 11-20-2011, 06:21 PM   #13
kcfirstbuild
I took a dremel - since that's all I have at the moment. I then cut some slots in the the carriage head to take a flat screw driver. I'm letting them soak in PB for a couple more days before I try it. I did go under and cut off the bolt i could get at with my 4" grinder. I think I might have to take a wire wheel to a couple of bolts they are covered with 40 year old undercoating. Wish me luck
Old 11-20-2011, 06:50 PM   #14
57larry
I agree but my hot wrench is a lot cheaper to purchase
Old 11-21-2011, 12:45 AM   #15
WIDESIDE72
WIDESIDE72's Avatar
I was lucky and when I pulled the last 72 bed, I took a piece of 2x4 had a friend place it on top of the bolt edgeways and stand on it. After spraying them several times over a few days with PB Blaster, te bolts came off fairly easily. We are lucky in Texas when it comes to rust. I have had other parts where I had to give up and get out the hot wrench.
WIDESIDE72 is offline   Reply With Quote
Old 11-21-2011, 08:20 AM   #16
rob32472
If you have a welder weld a bolt to the head of the carriage bolt and remove.....
rob32472 is offline   Reply With Quote
Old 11-21-2011, 01:51 PM   #17
JORGIE95961
best way is to just tighten them.. BAM!!! they breal right off.. i just tore apart two beds and after spending an antire day taering appart my origional bed with a rotten floor i wentto my buddys house for my new floor he just tightend them till they broke.. 45 minutes latter wallaa.. piece of cake
JORGIE95961 is offline   Reply With Quote
Old 11-21-2011, 02:22 PM   #18
Rooster's 67
Rooster's 67's Avatar
nut splitter
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 11-21-2011, 02:49 PM   #19
dfwright
dfwright's Avatar
What is a "hot wrench"?
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 11-21-2011, 05:39 PM   #20
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Oxy-acetylene torch. Also called a smoke wrench.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 11-21-2011, 06:58 PM   #21
57larry
you kids. don't worry, Daddy's here to teach you
Old 11-21-2011, 08:35 PM   #22
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
I always liked the term "fire wrench" it sounds more badazz
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 11-22-2011, 12:07 AM   #23
ItsRandy
ItsRandy's Avatar
"Blue" wrench has been used by me a time or two.
ItsRandy is offline   Reply With Quote
Old 11-22-2011, 12:11 AM   #24
Rooster's 67
actually called a "Blue tip" wrench ( a play on words for "bluepoint" one of snap-ons brands.
Used to remove/loosen bolts, heat metal for bending, cut metal, and warp sheet metal when used for brazing/welding. Also very good at catching flammable objects on fire and causing rubber components to smoke excessively smell like sheet and cause a big mess.
Im sure I have missed a few uses.
Old 11-22-2011, 12:13 AM   #25
Rooster's 67
Disclaimer: do not try at home or at all very dangerous.
Also used to fill potato cannons with very effective mix of combustible gases.
Will cause potato cannons to become shrapnel ask me how I know...lol now
