Old 11-17-2011, 05:58 PM   #1
grs
Coil wire.
Is this wire for checking the rpm's. The wire by the coil. I never had a TBI carb truck before. It is on a 1987, with a 305.
grs is offline   Reply With Quote
Old 11-17-2011, 11:43 PM   #2
Zane M
Re: Coil wire.
Yep, that is where I plugged my tach in.
Zane M is offline   Reply With Quote
Old 11-17-2011, 11:45 PM   #3
MadManAndrew
Re: Coil wire.
If I'm not mistaken, something else plugs in there as well.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 11-18-2011, 01:14 PM   #4
grs
Re: Coil wire.
My coil is good, but if I need a new one what brand should I get?
Old 11-18-2011, 10:03 PM   #5
wyattglock
wyattglock's Avatar
Re: Coil wire.
AC Delco replacement is the best way to go for stock replacement. No matter who you go with, drill the rivets out of the stock bracket and use the new bolts to install the coil in the stock bracket. It is much stronger and looks stock when you are done.
wyattglock is offline   Reply With Quote
Old 11-19-2011, 10:50 AM   #6
grs
Re: Coil wire.
Thanks. My coil has bolts in the bracket. It may have been changed at one time. I may replace it even tho it is running alright. If we sell our house we will be moving to Texas. I will drive it over 900 miles, and I don't want it to give me any trouble. I live in Joliet, IL.
Old 11-19-2011, 07:00 PM   #7
wyattglock
wyattglock's Avatar
Re: Coil wire.
No problem! I put an MSD Streetfire coil on my truck, but I also upgraded the distributor and valvetrain. I am planning on an MSD ignition in the near future, so I just figured I would go with a little hotter coil. But for street driving and no major upgrades, I think the AC Delco is definitely the way to go.
BTW, I don't live to far south of you. I am in Lafayette, IN, right across the river from Purdue.
Old 11-19-2011, 07:29 PM   #8
grs
Re: Coil wire.
Thanks.
