Old 11-13-2011, 03:03 PM   #1
cfacundus
Auto column shifter tabs?
I really do not know what to call them but on my 64 auto column there are 3 metal tabs that hold the shift indicator to the actual steering column. 2 of the tabs are broken off and one of the broken ones were found. Has anyone ever tried welding these back on or have any idea on a good fix. Will it maybe interchange with some other older chevy car part because from what I have read these auto truck columns are hard to come by.I have tried doing some searching online but have sort of come up dry.
-Thanks
cfacundus is offline   Reply With Quote
Old 11-19-2011, 09:32 PM   #2
cfacundus
Re: Auto column shifter tabs?
These are what I am talking about. I pulled the tube and tried welding today but one broke off in the way back in. I am not much of a welder though
Old 11-19-2011, 09:51 PM   #3
Rooster's 67
Rooster's 67's Avatar
welding them back would be best, and fabricate the fourth, going to have to mig with gas probably .025 wire and a good machine for lower heat settings, Ideally you would want to tig that back together. make sure it is clean as you can get it, and no rust.
good luck.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 11-19-2011, 09:59 PM   #4
cfacundus
I have a pretty good mig Century 180 220v with a bottle and small wire. I am just not very good at using it. I tabbed the third. Where does the fourth go? Any pics available for reference?
Old 11-19-2011, 10:08 PM   #5
Rooster's 67
If I recall, there are only three, the turn signal switch sits on top of them right?
Old 11-19-2011, 10:40 PM   #6
cfacundus
Yeah that is all I could see spots for but you threw me for a loop when you said fab the fourth
Old 11-20-2011, 12:26 AM   #7
Rooster's 67
Yeah sorry bout that,seen alot of columns in my days as a tech, had to rattle the drawers up there and blow dust and cobwebs out. lol
