64-66 front suspension
Has anyone found any other springs that work to lower the trucks.
I know there are lowering springs, but do springs from any other vehicles work? |
![]() Join Date: Aug 2004
Re: 64-66 front suspension
Keep tj springs work for the rear but you sacrifice load cuz they ae light duty, I have some front springs, 1.5"drop I won't use, I'd like to get $60 plus ship if ur interested
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Jeep Wrangler TJ 1997-2006 springs like said above to lower the rear you can also use 70's chevelle springs to lower the rear.
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
All three of my trucks i just cut the front coils, i think somebody on here used s10 springs once but cant remember who and would want to confirm with them before i tried it, besides that the only other thing i know far as springs is to buy drop springs, but im cheap and cut mine.
#7 | |
CPP has front lowering springs 1 to 3 inches for less then 100 bucks.
http://www.classicperform.com/6092chevtrk.htm#21
Billy 65 C10 ............................... ____ ................ ________-|___\____ .;.;;.:;:;.,;.|__(O)___|____/_(O)| _______________________________ P.S. Send truck money ! |
#9 | |
good looking out do they charge s&h |
I'd guess around $20, I'd sell and ship for 80.00
Just keep the bags on it. You could put a shrader (sp?) valves on it and use a portable tire pump that plugs into the lighter if you need to raise it. That's what I did for years with my 89 C1500.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
That's what Ive been doing. I've been looking for a portable air compressor to keep with the truck. The thing is it take a minimum of 150psi to get the front up. A tire pump took like 25 minutes to pump it up.
Anyone ever try '68-'72 small block Chevelle coils? Don't know if they'd lower it any, but the ride would be alot softer. Just a thought.....
_____________________________________________ Ray All my life, I've been told I'm a "Bad Influence" |
#15 | ||
![]() http://67-72chevytrucks.com/vboard/s...evelle+springs
#16 |
I was referring to Chevelle front coils in the front of a pickup
