Old 11-19-2011, 11:49 PM   #1
pritch
pritch's Avatar
How water tight is your truck bed?
Ol Green, my '68 C-10, has a water tight bed. Every time it rains the bed holds water (where I usually park is a little bit downhill, nose down) I've started backing in so it will drain. I'm thinking about drilling a couple drain holes, you know, because I don't want water standing in the bed. But I hate to drill holes in things.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 11-20-2011, 12:04 AM   #2
SS Tim
SS Tim's Avatar
Re: How water tight is your truck bed?
I've always parked to allow the bed to drain. Drilling holes won't get rid of all the water (ribs and bolt heads). If you do drill, watch where its going to go. Don't want to make things worse. Wait..... you have a panel and a water problem.... might need more than drain holes! :-)
SS Tim is offline   Reply With Quote
Old 11-20-2011, 12:12 AM   #3
pritch
pritch's Avatar
No, no water problem in the Panel
This is on my pick-up.
'68 Panel
'68 C-10
Ol' Green
Old 11-20-2011, 12:34 AM   #4
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
My '71 has two holes in the front of the bed that drains off the accumulated water. They look like they came that way from the factory, but I could be wrong. I am sure that two small holes drilled into the front of the bed where it meets the front panel will solve all your problems. Just make sure that the water that drains from the bed goes on the ground and not into a bed rib or something of the sorts!!!
Mike
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 11-20-2011, 12:41 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by schwoch1 View Post
My '71 has two holes in the front of the bed that drains off the accumulated water. They look like they came that way from the factory, but I could be wrong. I am sure that two small holes drilled into the front of the bed where it meets the front panel will solve all your problems. Just make sure that the water that drains from the bed goes on the ground and not into a bed rib or something of the sorts!!! Mike
Both of my trucks have holes on either corner in front of the bed.
68gmsee is offline   Reply With Quote
Old 11-20-2011, 09:09 AM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
X2 they do get stopped up time to time, but all my trucks have them
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 11-20-2011, 09:09 AM   #7
cdowns
cdowns's Avatar
i've always enlarged the factory stock drain holes a bit. but it doesn't take much for them to get clogged up and retain water in the bed// leaves and pine needles were my biggest problem
Old 11-20-2011, 04:59 PM   #8
pritch
pritch's Avatar
So there are factory drain holes? Mine must be clogged up. Where are they exactly?
'68 Panel
'68 C-10
Ol' Green
Old 11-20-2011, 05:32 PM   #9
sameyrasmea72
sameyrasmea72's Avatar
If they are kept clean they work good. even the ribs on the floor don't prevent drainage because the ribs don't go all the way to the headgate.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 11-20-2011, 05:54 PM   #10
pritch
pritch's Avatar
Thanks for that picture, Sameyrasmea72. If it stops snowing long enough today, I'll go check it out.
'68 Panel
'68 C-10
Ol' Green
Old 11-20-2011, 06:24 PM   #11
lil hoodlum
lil hoodlum's Avatar
Yep! Mine has those too! Mine usually get stoped up with a small piece of trash, leaves, or even an occasional bolt will plug 'em up!
Keith
lil hoodlum is offline   Reply With Quote
Old 11-21-2011, 07:51 AM   #12
I enlarged mine a it and they still clog. After it rains I always check. I have a saddle tool box so I have a stick handy to reach under and wipe away any debris. I clear debris on a regular basis. It sucks not being able to store the truck inside or under cover,so a little extra effort helps preserve it as best as possible.
