Gauge Cluster Light Bulbs
Do you know if are there LED light bulbs and where can I buy them
needs more $$$
Re: Gauge Cluster Light Bulbs
superbrightleds.com
194 is what you're looking for, but get the 360 degree version...the kind that point straight aren't bright enought IMO. You only need 4 of the 360 kind, just for the ones that light up the guages. The rest of them you can use the 1 direction which are cheaper if you feel like replacing those as well.
1970 2wd Blazer |
Thank you Tubbed II
There are two kind 194 360 degree which did you use |
needs more $$$
I currently have these in all the lights holes in my cluster (WLED-x5 Cool White)
![]() But like I said, they aren't bright enough because of the single direction. They work good for all the indicator lights, but the gauges could be a bit brighter. I'm gonna go with the WLED-xHP6-AC's when I get the new ones because they are the cheapest: ![]() Really, I'd rather go with the WLED-xHP5's because they are brighter, but they don't come in Cool White and I like the semi blueish tint they give off. The next available 360 degree one that comes in Cool White is $12 a pop, and it's just not worth it and might even be too bright since there's no way to dim them.
1970 2wd Blazer |
Thanks I just order those WLED WHP5'S,I ordered only four as you said,As soon as I get them I'll take pictures.
needs more $$$
Cool! I'm anxious to see how they look... What temp/color did you go with?
1970 2wd Blazer |
Superbrightleds are very fast sending orders I placed the order on thursday morning and received on saturday noon.
are only two on speedometer and two on the other side, perhaps I order two for for center This picture is during day. I'll see tonight ![]() Uploaded with ImageShack.us |
Thank you TUBBEDII
needs more $$$
No problem! Based on the picture alone, it's much brighter than what I'm running. I don't have that type of cluster, but I think all the lights in the center are just going to show your indicators when activated (turns/dummy lights), not illuminate the area.
Post the night time pics if you took them!
1970 2wd Blazer |
