11-21-2011, 01:44 AM | #1 |
Gear ratio???
Can anybody please tell me what gear ratio i have in my 78 c10?. It has a straight six 250ci,it came with a 3 speed on the colom but i changed it to automatic turbo 350 tranny. Thanx!
Posted via Mobile Device |
11-21-2011, 01:54 AM | #2 |
C/10 junkie
Re: Gear ratio???
My 68 292 has 3.73 gears with a 4 on the floor
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
11-21-2011, 02:54 AM | #3 |
Re: Gear ratio???
I think thats what i got 3.73's, but iam not too sure.
11-21-2011, 07:18 AM | #4 |
Re: Gear ratio???
Per the Powertrain Chart in the archives at the GM Heritage Center, base axle ratio is a 3.07:1.
http://www.gmheritagecenter.com/gm-h...olet-Truck.pdf (page 5) Optional ratios are usually shown on the SPID label. Do you still have the SPID label on it? Does it show a ratio on the label, like "GU6" (3.42) or "GT4" (3.73)? At any rate, all this assumes it's never been changed. The only way to know for sure is to pull the cover and count teeth. Change the fluid while you are in there - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-21-2011, 07:20 AM | #5 |
Re: Gear ratio???
As an aside, if you have the ability to travel a measured distance in a certain amount of time, then we can calculate the rear axle ratio using the "N/V" ratio formula.
Let me know if you want more detail on that. K
11-21-2011, 08:04 AM | #6 |
Re: Gear ratio???
My 84 250/TH350C has 3.08's
My 81 3/4 ton 250/3OTT has 3.43's My 77 250/3OTT has 2.7? 's
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
11-21-2011, 08:27 AM | #7 | |
Re: Gear ratio???
K
11-21-2011, 12:26 PM | #8 |
Re: Gear ratio???
I just changed the fluid,but i forgot to check. Iam guna open up the cover again anyway because i got a little leak. Its more likely my gasket. Then this time ill count.
11-21-2011, 12:35 PM | #9 |
Re: Gear ratio???
Gmheritagecenter helps alot. Thanx!
