05-13-2011, 01:40 AM | #26 |
Re: My 1964 C10
today i got the "new" clutch put in (was bought in '97 but never installed). dropped the motor in but havent bolted it down yet due to concerns about header installation, put on new carrier bearing, and got my air bags plumbed. my rear bags are slowly leaking right now but i haven't started rechecking fittings yet, maybe tomorrow.
1st pic- motor put in- bags aired out 2nd pic- my cleaned up gauge cluster 3rd pic- bags aired up
2003 Serria K1500 1998 Camaro 1964 C10 long fleetside bed, small back window, 3 on the tree 1964 C20 custom cab, long fleetside bed, big back window, 4 on the floor Disclaimer- anything posted is only based on my personal experience, opinions, and advice given by others. There are no implied or written warranties or guarantees with anything posted on this website. |
05-13-2011, 09:23 AM | #27 |
Re: My 1964 C10
You may have the same issue i had here IF you are referring to the header and clutch linkage concerns. On mine, the down leg of the clutch pivot arm was hitting the rear header tube. I heated the arm right where it is welded to the tube and bent it inside until it cleared the header. Then i got a 3/8" heim joint and threaded that onto the end of my clutch rod so it would all rotate as it should. So far it appears that it will work perfectly. I will try to get some pics of what i did this weekend for ya. I am running headers for a 73-87 truck.
05-13-2011, 11:08 AM | #28 |
Re: My 1964 C10
that would be very helpful. i have been wondering about the clutch linkage, the 3 on the tree linkage, and how will they clearance the frame.
05-20-2011, 12:15 AM | #29 |
Re: My 1964 C10
Monday i got my headers in and installed. both arms on the z bar were hitting header tubes, so i bent the one that hooks to the pedal outwards and the one that connects to the clutch arm I cut off and moved it 7* rearwards this getting the proper clearance.
Tuesday i fabricated most of my exhaust (need to mount the bed to figure out where the tips are going to be mounted) I had to make my own collector flanges because nobody in town had the right ones, and im impatient. the exhaust comes out of the headers then ducks under the frame and outside the frame.
2003 Serria K1500 1998 Camaro 1964 C10 long fleetside bed, small back window, 3 on the tree 1964 C20 custom cab, long fleetside bed, big back window, 4 on the floor Disclaimer- anything posted is only based on my personal experience, opinions, and advice given by others. There are no implied or written warranties or guarantees with anything posted on this website. Last edited by 1964c-10; 05-20-2011 at 12:26 AM. |
05-20-2011, 12:25 AM | #30 |
Re: My 1964 C10
yesterday i made an alternator bracket (according to the parts store they don't make alternator brackets for headers)and finished hooking up the motor, tried starting but my dissy was off a tooth, moved it and wasn't getting any spark anymore. put in new dissy today with the same problem, finnaly figured out that the dissy was properly grounded when i first tried starting it but after moving it a tooth i didn't put the clamp back on causing it to not be grounded.
finally today i got the motor started and ran my front brake lines v a couple more exhaust pics- i have about 6" of clearance between the collectors and the ground
05-20-2011, 02:28 AM | #31 |
6>8 Plugless........
Re: My 1964 C10
Nice progress! Are you planning on having it done enough to take it to Good Guys?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-20-2011, 01:15 PM | #32 |
Re: My 1964 C10
yeah thats the plan i dont know if ill have the whole thing done or not
05-20-2011, 01:29 PM | #33 |
Redneck Hillbilly
Re: My 1964 C10
Nice looking project you've got going on there. Seems to be coming together very nicely.
05-20-2011, 03:30 PM | #34 |
Re: My 1964 C10
Even if it isn't 100% done, as long as you can drive it safe, bring her on down man!
05-21-2011, 01:14 AM | #35 |
Re: My 1964 C10
thanks fryer!
Ryan at the very least it will be a chassis/cab, i'm more concerned if it will be legal to drive it by then, i havent really checked into what i need to do to get it reregistered and licensed yet
05-30-2011, 01:12 PM | #36 |
Re: My 1964 C10
well i finished getting the brake lines installed yesterday, and got my shifter linkage working working properly.
i took the truck out for a couple laps around the barn yard yesterday - this was my first time ever driving the truck and it was a blast!
06-16-2011, 02:38 AM | #37 |
Re: My 1964 C10
well i broke my hand about 1 1/2 weeks ago and had to have 2 pins put in it, so progress has been pretty slow lately between that and the summer class i have been taking.
lately i have been working on piecing my bedsides together, i had to graft the top portion of 1 bedside onto another, and both sides needed rear quarter panels, and the part that the tail light mounts to. i might be laying some bondo tommorrow hopefully. i recieved my power lock/ alarm kit from Classic Industries last week and have it wired up as much as possible right now, still need to do some sheet metal work, sand blasting, and bondo on the doors. i think the only major parts that i am still needing are my carpet and seat covers which are on back order at Classic Industries. For those who may not know, i am planning on having this truck painted and put back together for the Good Guys show in Des Moines July 1-3. my deadline is creaping up fast, but if i get those parts in i think i can make it!
07-10-2011, 02:17 AM | #38 |
Re: My 1964 C10
well i got everything into paint now and am working on reassembling whats left. we put the front and rear glass in last week. yesterday and today i put my new wheels on and got the drivers door put on and together.
i will put up some new pictures later
07-11-2011, 02:27 AM | #39 |
Re: My 1964 C10
pics
07-11-2011, 07:47 AM | #40 |
Re: My 1964 C10
I can't wait to see this thing in person,good progress keep it up
07-11-2011, 11:28 AM | #41 |
Re: My 1964 C10
Man, it's coming together great! Do you have any new dead lines for it you'd like to meet?
08-23-2011, 07:00 PM | #42 |
Re: My 1964 C10
alright, i havent updated this in quite a while because ive been pretty busy lately but i got the truck on the road now and have probably driven it 150 miles or so. im still working out the kinks but it is driveable. still have to put the tailgate on and put some parts in the doors and some other misc. stuff to do.
i have alot of pictures to post up so im not sure if they will all be in the right order...
08-23-2011, 07:05 PM | #43 |
Re: My 1964 C10
more pics of the first test drive
08-23-2011, 07:12 PM | #44 |
Re: My 1964 C10
pics with the front end on
08-23-2011, 07:31 PM | #45 |
Re: My 1964 C10
pics right after the bed was put on
11-17-2011, 02:51 AM | #46 |
Re: My 1964 C10
Oh My! This truck came out looking awesome! Thank you for posting the photos.
11-17-2011, 05:31 PM | #47 |
Re: My 1964 C10
Jason, your truck turned out awesome! we should have a GTG at your place! Your shop is sweet!
11-20-2011, 11:57 AM | #48 |
Re: My 1964 C10
Jason,I'd be proud as Hel- to drive a truck as nice as yours. It really turned out nice.
11-21-2011, 04:07 PM | #49 |
Re: My 1964 C10
I have to agree with all the above, very nice wrap up, you should be proud!!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
