![]() Join Date: Oct 2011
Hi everybody. Have you ever reworked a factory cruise control to get it working agan? Mine worked a couple of times ten years ago. Then i wrecked the truck. Removed the front clip after the crash. Then it sat until last year. I put it back together. I dont think the vac lines are right. Does anyone have any photos of a corect install? Thanks terry
Restoration Virgin!
Re: 1972 C/20 factory cruise control problem.
ttt...any help here?
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
The service manual has a section in the back that covers it. I don't remember if it shows the vac line routing.
A is the large fitting that comes back to the tee fitting, B is the smaller fitting that goes to the engine vacuum.
A is also connected, by way of the tee, to the shut off valve at the brake pedal A is also connected, by way of the tee, to the vacuum servo, and off of the tee goes to C ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-21-2011 at 03:14 PM. |
![]() Join Date: Sep 2001
The only problem I have had was when my brake pedal switch was not adjusted right. As mentioned above, the '71 service manual has the cruise stuff in it. If you need parts, the transducers and servos do pop up on Eaby now and then.
Good Luck!! |
Thanks for the help. I am going to print the diagram and check my routing.
