08-22-2003, 03:44 PM | #1 |
wtb t350 for a 4x4
i need t350 for a 4x4 in good working order..
anyone close have one???i can buy it or trade for it.. thanks jamie
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
08-22-2003, 04:24 PM | #2 |
I have a core for $100 or rebuilt for $350 plus ride.
1957 Cameo |
08-22-2003, 09:35 PM | #3 |
Is there something unique about the 4x4 turbo350 verses a 2x4 turbo 350?? Can't you pull the tailshaft and bolt it up to the transfer case with the appropriate adapter? I know where you can get a good running turbo350 2x4 pretty cheep. In fact I know wher you can get 3 of them!!!
08-23-2003, 04:00 AM | #4 |
Output is a lot shorter.Other than that, the case itself may be heavier, I know a k case 400 is heavier than a car, but it will still work. Not 100% sure on t350's. Anyone else?
1957 Cameo |
08-25-2003, 01:09 PM | #5 |
SKINNY TIRES RULE!
The "K" case is a thicker aluminum and has with an aluminun flywheel cover. I believe the "K" case started in the mid 70's. A lot of rebuilt transmissions are 2wd cases with the 4wd output shaft.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
