11-21-2011, 12:15 PM | #1 |
In tank Fuel Pump Options
I have a 02 5.3 that i am putting in my 55 project and i am using a fuel tank from TBI Fuel injected blazer blazer and i want to use the stock sending unit and have a in tank pump, what are you guys using, and i know know there is some cheap walbro knockoffs of fleabay but has anyone used one of these, with any luck, I bought a used tank from an 02 camaro and was going to ues that untill i tried testing it and found out it didnt work, so i dont want to buy another used one that has been sitting only to have that agian
Thanks for any insite on this |
11-21-2011, 08:15 PM | #2 |
Re: In tank Fuel Pump Options
I use A/C Delco part# EP376 in all TBI tanks when running a LS or LT engine. These pumps were factory on LT1 powered F-bodies, Y-bodies & B-bodies. Be sure to use high pressure 5/16" hose between the sender & pump.
A quick look on Ebay showed this http://www.ebay.com/itm/NEW-AC-DELCO...item588ffefd8d $50 bucks with free shipping. I dont trust knock-off anything. |
11-21-2011, 10:46 PM | #3 |
Thanks for the info and link, I would feel a lot better with the ac delco part you found, that's the same price as the knockoff, I'll go that route for sure.
Posted via Mobile Device |
