Wheel/tire picture thread
I saw a similar thread on another forum and I thought I should post it on here for everyone to share. There are alot of threads asking about backspacing, tire size etc, so this is a chance to share what you have as well as inform others
things you need to post if you can:
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Re: Wheel/tire picture thread
Reserved for when I get my new wheels......in the next few weeks...
My old wheels
wheel size front/rear 18x8 f 20x10 rear - tire size front/rear 255.50.18 front 295.45.20 rear - make/model of tire continental contact - make/model of wheel coys c5 - backspace 5.25 front and 5.5 rear
Frequent Flyer
20” Billet Specialties Roulette Wheels with BFG G-Force T/A Tires
20x8.5 with 4 3/4" BS front with 265/50/20s 20x10 with 5" BS in rear with 295/45/20s |
The Niner
![]() Join Date: Nov 2010
Wheels -
F*rd steel wheels 16 X 7 all the way around. 4.5" backspacing. Tires - Michelin LTX M/S2 265/75/16 all the way around. ![]()
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
^^^ I have to ask, Sicklajoie, do you still have the six lug setup on your truck? And out of what ford did you get those wheels? I like the look.
I just picked up some rallys and tires, and thanks to this forum found alot of usefull info. Even with all the measurments, I was still unsure I was picking the right tires.
Fronts 15x8 stock BS on BFG 245/60/15, Rears 15x10 5.25 BS on BFG 275/60/15 72 C/10, stock rearend width. Tires: Paid 110ea for rears, and 103ea fronts.. I'll be taking these home tomorrow to see how they fit/look. Waiting on new shoes, sanding flames off, new solid matt finish coming soon.. ![]() One side is about .25 closer to edge, than other side.. ![]() ![]() ![]() ![]() ![]() Last edited by bajaracing; 11-23-2011 at 01:47 AM. Reason: added pic |
#8 | |
The Niner
It's a C/20 so it's an 8 lugger. By 16 X 7 wheels I meant they're 7 inches wide. The F*rd wheels are from pretty much any 3/4 ton pickup or van up until the late 90's.
Al I think it would also be a good idea to state what drop and suspension mods have been done.
Here's what I have. 68 Stepside. 3.5/5 drop 15x8 (3.75"bs) on all four corners. Tires: BFGoodrich T/A Radials 275/60/15 rear, 255/60/15 steer ![]() ![]() ![]() Same 3.5/5 drop but with 17x9.5(5.5"bs and 7/16" spacers) 275/55/17 rear, 17x8(4"bs) 255/50/17 front. Tires are Hankook Ventus ST RH06 ![]() ![]() ![]() ![]() ![]() Same wheel/tire combo as above but with 3/4" drop block in rear for 3.5/5.75 drop. ![]() ![]() ![]() ![]()
Restoration Virgin!
I have a CPP Grand Slam 2"/4"....these are 6 lug rally's...15x8 fronts (235/60/15) 15x10 rears (275/60/15) Uniroyal Tiger Paw's
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Stock 6 Lug Rallys 275/60/15
Stock 1969 C10 with 8" Rallye's 275/60/15 BFG Radial Drag TA's Front / Rear.
If I did again, would go a size or two smaller on the front.
1971 GMC Sierra 3/4 Ton 4x4 1972 Chevrolet SWB 4x4 RIP LeRoy |
![]() ![]() Join Date: Jan 2011
Truck is a 69, 68 clip. 84 front suspension swap. 2.5" McGaughys drop spindles and one turn cut from the stock small block springs. (could change soon, PO cut the springs)
I had the engine in my truck this spring and had a problem. It had to come back out. The pics you see with the new wheels are more current, the pics with truck rallys are to show how much the big block will bring the front end down once I get it back in. The tires on the rallyes are 215/65 I think, .. 4.5" drop in the front with 1.25 HD rotors. (I gained about .5 in track width) .. and a big block with iron heads. 6" drop springs in the back, no wood in the bed, not much gas in it, bumper, or driver's step fender on it. It may come down another 2" when I get my notch in place. .. or bags.. ![]() The wheels are Billet Specialties Dagger. F 20x8.5 5.5" BS 255/40/20 Nitto 420s R 20x8.5 4.75" BS 255/45/20 Nitto 420s I have the earlier rear end housing. 55.5" plate to plate. These wheels were measured 316,543 times with a Percy's wheelrite. I'm confident I can tell you .. you can't get much more than this under a stepper without cutting something somewhere. I have heard 22x9 with 5" BS will work with minor trimming. I just offset mine to keep from having to cut my fenders. My tires will tuck completely into the wheel wells, no rubbing with about 3/8" clearance on either side in the back. You just can't get as much tire under a stepper !! ![]()
Cool Truck
16x8 all the way around - tire size front/rear 265/75/16 all the way around - make/model of tire Michelin LTX M/S2 - make/model of wheel ION Alloy 171 - backspace 4.25 ![]() ![]() Love your set up Sicklajoie, I might have to get some of them rims, paint them black, and get a set of caps to use in the winter.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
- wheel size front/rear:
Front = Stockers - 15x6.5 Rear = Custom made - 15x8 - tire size front/rear Front = 225x75 Rear = 255x70 - make/model of tire Make = Khumo Model = Road Venture - make/model of wheel Front = Stock Rear = Wheel Vintiques 15x8 - backspace Front = Stock Rear = 4 1/2 inch backspace - picture of the truck/blazer/suburban open to all years
66 GMC Suburban Custom 66 Chevy K10 Suburban |
#15 |
Next, sanding flames off, new solid matt finish..
![]() ![]() Last edited by bajaracing; 11-22-2011 at 11:42 PM. Reason: updating pic |
#16 |
laying low
![]() Join Date: Mar 2001
That's lookin goooood.
Tags |
backspace, backspacing, tires, wheels |
