Old 11-22-2011, 12:42 PM   #1
JJanzen
JJanzen's Avatar
Hub Cap Help Needed
Would someone with knowledge of hub caps let me know what these are off of? I am wanting to use these on a 71-72 5 x 5 steel 15" wheel. Is it possible or am I dreaming? Thanks for the help! Joel
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 11-22-2011, 01:28 PM   #2
flashed
Re: Hub Cap Help Needed
I think those are from a 67 or 68 truck but someone else with more knowledge will chime in.I have 3 of those hanging on my wall ,been hoping to find a fourth just to make an even set.
flashed is offline   Reply With Quote
Old 11-22-2011, 01:35 PM   #3
They won't fit. These are the inner clip type used on pre-69 8-lug trucks. There is an identical in appearance hubcap made for the 6-lug 1/2 tons that mounts on the outer nubs,just like the 69-75 and 76-91 style.
Old 11-22-2011, 01:39 PM   #4
JJanzen
JJanzen's Avatar
Is there a hub cap made in this style that would fit the nubs on a 5 lug 71-72 wheel?
Blue72
Red72
Old 11-22-2011, 06:54 PM   #5
flashed
I need to look at my 3 caps and see if they are like that on the back .
Old 11-22-2011, 09:14 PM   #6
nds1968
nds1968's Avatar
Yes, They look just like those on the outside but the opening on the back is bigger and measures roughly 10-1/4" and fits nub style rims.
http://67-72chevytrucks.com/vboard/s...=dog+dish+caps
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 11-22-2011, 11:58 PM   #7
Meatman
Meatman's Avatar
I still think it would be easy to transfer the clips to a 16" wheel. I still have the split rims on my truck that I am just going to scrap and I might have to try it.
Daily-94 K2500 350 5spd extended cab longbox
Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack.
Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881
My 01 TA and 88 Formula hide in the garage. :-)
Meatman is offline   Reply With Quote
Old 11-23-2011, 11:19 AM   #8
JJanzen
JJanzen's Avatar
Meatman, Any chance you could post a pic of the clips? Sounds like the easiest solution. Has anyone ever tried this and with any luck?
Blue72
Red72
Old 11-23-2011, 04:21 PM   #9
...There is an identical in appearance hubcap made for the 6-lug 1/2 tons that mounts on the outer nubs,just like the 69-75 and 76-91 style.
Yes,that's what I was trying to say. The 67/68 1/2t caps are outer nub type and look identical to the ones you are asking about. 67-70 are 6-lug wheels and 71-91 are 5-lug. They all take the same size hub cap,so they can be interchanges. All the GM car hubcaps fit,too. So do Fords and some others,if you don't mind another make's name on your truck .
I just went out and took some pictures. All these hub caps will fit:
Old 02-20-2017, 06:51 PM   #10
the67Beast
Active Member
the67Beast's Avatar
Came stock on my 67 C-10 Pickup.
the67Beast is offline   Reply With Quote
