Old 11-24-2011, 01:20 AM   #1
tomsprojects
tomsprojects's Avatar
Cool 68 Four door build
Well Im starting a four door build some what simular to Drews. I will try to show the progress as I go along with the build.
My build starts off with a 1968 sub. that is a factory 1 ton 4x4 one owner Arizona truck with a 6 cylinder 4 speed.
Truck # 2 is a 2011 silverado extended cab which i will use the fire wall , some of the floor and all of the drive train which only has 5k miles on it. The motor is a 5.3 and the trans is a 6 speed auto which should be very reliable.
Truck #3 is a 71 GMC 3/4 ton withe a very clean cab and doors in which I will use the back half of.
All of the parts I dont use will be for sale to who ever needs them.
I am open to any suggestions on this project.
tomsprojects is offline   Reply With Quote
Old 11-24-2011, 01:25 AM   #2
67chevy1series
67chevy1series's Avatar
Re: 68 Four door build
intresting... im in
67chevy1series is offline   Reply With Quote
Old 11-24-2011, 04:32 AM   #3
tomsprojects
This is one of my projects I built, it was a original 2wd blazer that was burnt to the ground and sat in a back yard for years until i got it and put a late model motor and trans in it and a complete resto. This is a great little blazer.
Old 11-24-2011, 05:34 AM   #4
tomsprojects
maybe I will call it (Burban Blues) what do you think?
Old 11-24-2011, 09:44 AM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Can't wait to watch this come together.
Where did you locate the 2011 donor?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-24-2011, 09:54 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Im in what the heck was the sub used for chasing storms or something?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-24-2011, 10:45 AM   #7
steppside69
steppside69's Avatar
I'm in. Sounds like a very cool build!
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 11-24-2011, 12:21 PM   #8
dsy1
Nice project. Only 257,500 more views and you can tie Drew (but his is still a moving target).
dsy1 is offline   Reply With Quote
Old 11-24-2011, 12:35 PM   #9
tomsprojects
The Silverado was on craiges list for two thousand dollars, what a score that was. The suburban is coming out of Arizona tomorow when I go and pick it up, 7 hour drive one way. I think the suburban was used as a camping vehicle.
Old 11-25-2011, 09:24 PM   #10
tomsprojects
Re: "Mad Max" 68 Four door build
Well my daughter and I went for the 6 to 7 hour drive to pick up the suburban from Benson Arizona and it turned into a 10 hour drive one way. When we got there the paper work was in a bag that said mad max so I will call it that for now. The suburban is so clean I hate to cut it up but we all must make sacrifices. The burb is a factory 6 cylinder 4 speed 4x4 with the cleanest no rust body I have seen in a long time and it only has 69k miles on it. As I'm typing this we are waiting for a pizza here in Gila bend Arizona and still have hours and hours of driving to go tonight. I will post more pictures when we get home with this jewel.
Old 11-25-2011, 09:37 PM   #11
63chevyll
gets board easy.......
63chevyll's Avatar
This is gonna be nice.
Cool blazer too
63chevyll is offline   Reply With Quote
Old 11-25-2011, 10:29 PM   #12
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Sweet project, I'm in too! Sweet Blazer BTW!
Ryan
1969 Chevy milk truck
Old 11-25-2011, 10:41 PM   #13
Hduramax
Hduramax's Avatar
sounds like a sweet project, nice score on the donor 2011
2008 HD
2010 Camaro 2ss (The Wife's Ride)
2005 Suzuki GSX-R 1300 "Busa"
1969 C-10 (under Construction)
2013 Sonic LT
"LIVE LIFE,TASTE DEATH"
Hduramax is offline   Reply With Quote
Old 11-25-2011, 11:09 PM   #14
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That was an amazing deal on the 2011 drivetrain.
-Nate
Old 11-25-2011, 11:16 PM   #15
VA72C10
VA72C10
VA72C10's Avatar
Awesome project. Sounds like I want to do but not sure if I'll ever have the time/cash to pull it off....
Glad you're going to do the 4th door....will be a lot of work but WELL WORTH IT!!! Will put this build over the top on the cool factor!!!
Which front end are you going with? Short or long bed and stock height, lifted, or lowered?
Old 11-26-2011, 08:55 PM   #16
Hart_Rod
Hart_Rod's Avatar
Another cool project.
Hart_Rod is offline   Reply With Quote
Old 11-27-2011, 12:50 AM   #17
docrock
docrock's Avatar
Great project Tom. I can hardly wait to watch it in person.
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 11-27-2011, 01:17 AM   #18
tomsprojects
Re: 68 Four door build "mad max"
Well we finally made it home with the Burban. What a long drive that was, by the time we loaded it up it was huge on my trailer and we couldnt take advantage of that 75 mile an hour speed limit in Arizona (more like 50-60 tops) but it was with out any problems the whole way back.I will post more pictures tomorow after I get some sleep tonight.
Old 11-27-2011, 01:29 AM   #19
Racer2172
Im in great build
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 11-27-2011, 02:25 AM   #20
tomsprojects
Any one out there need the factory running gear out of this 4x4?
Old 11-27-2011, 02:39 AM   #21
jmedero
jmedero's Avatar
Sweet truck man. This will be fun to follow along.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 11-27-2011, 02:44 AM   #22
72LSK10
72LSK10's Avatar
Cool Snap-On sweater, oh and the burban is cool too lol
72LSK10 is offline   Reply With Quote
Old 11-27-2011, 10:26 AM   #23
tanman722001
tanman722001's Avatar
Yea if you was alot closer.Cant afford shipping.Going to be a cool build.
1991 GMC K2500 4X4 350/auto
1991 Chevy S10 ext cab.
1990 Chevy S10
1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto
tanman722001 is offline   Reply With Quote
Old 11-27-2011, 11:31 AM   #24
Ridnhi
Ridnhi's Avatar
I'm in too. Hope to see that fourth door! Nice score on the '11. I would have hated to have been in that truck when that happened. Good luck!
1972 K5 Auto 4x4 factory air
2007 Silverado extended cab Z71
Ridnhi is offline   Reply With Quote
Old 11-27-2011, 01:03 PM   #25
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
im in!
John
1999 Toyota Tacoma 4x4
