Old 09-27-2011, 09:35 AM   #1
chevykevy
chevykevy's Avatar
Under Dash Harnesses
I have two very nice underdsah Harnesses, One is from an automatic. It has the two plugs for the neutrl safety switch and reverse lights Not sure if it was in a guagew or dummy lights truck. The second is from a 1971 GMC 4 speed truck with guages. Both are very clean. $125 each shipped
AUTOMATIC HARNESS-SOLD
MANUAL HARNESS----Still Available $100.00
Last edited by chevykevy; 02-21-2012 at 09:16 AM. Reason: Update availability of parts
chevykevy is offline   Reply With Quote
Old 11-14-2011, 09:13 AM   #2
chevykevy
chevykevy's Avatar
Re: Under Dash Harnesses
ttt
Old 11-25-2011, 06:36 PM   #3
chevykevy
chevykevy's Avatar
ttt
Old 11-25-2011, 09:38 PM   #4
brickren
brickren's Avatar
Would the 71 work in a 68 K20 std?
1968 K 20 w/327 4bbl 4 sp
brickren is offline   Reply With Quote
Old 11-26-2011, 12:10 AM   #5
chevykevy
chevykevy's Avatar
I'm not sure. The 67 and 68 fuse blocks are mounted a quarter turn differently. They are the same in everyway, Ithink, except for how they are mounted.
Does anyone else out there know?
Old 11-26-2011, 12:40 AM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
I think the plug for the dash gauges is setup different due if you have dummy lights....but it can be reconfigured using GMC Paul's FAQ for changing the wiring into the plug...easy to do....
not sure on K20 either though
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 11-26-2011, 12:42 AM   #7
chevykevy
chevykevy's Avatar
The 71 , 4 speed harness, is a guages harness.
A harness is made to make it a dumby lights setup?
Old 11-26-2011, 12:59 AM   #8
gcburdic
Restoration Virgin!
gcburdic's Avatar
no...just the plug that goes into the dash bezel is wired different
Geoff with a G
Old 11-26-2011, 01:01 AM   #9
chevykevy
chevykevy's Avatar
got ya
Old 11-27-2011, 11:32 AM   #10
jaros44sr
jaros44sr's Avatar
Ill take the automatic one, if youll do 100 shipped, and questions answered
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-27-2011, 11:49 AM   #11
chevykevy
chevykevy's Avatar
What are your questions?
Old 11-27-2011, 12:10 PM   #12
chevykevy
chevykevy's Avatar
jaros44sr, pm sent
Old 11-27-2011, 02:25 PM   #13
jaros44sr
jaros44sr's Avatar
Ok, questions answered in pm...does the back of your fuse box look like this, my pink wire is the melted one
SAFETY FIRST
AS usual, off topic
Jim
Old 11-27-2011, 05:07 PM   #14
chevykevy
chevykevy's Avatar
mine looks like this
Old 11-27-2011, 05:09 PM   #15
chevykevy
chevykevy's Avatar
sorry, heresis the pic
Old 11-27-2011, 06:53 PM   #16
jaros44sr
jaros44sr's Avatar
Thanks for the pic, how do you want to be paid?
SAFETY FIRST
AS usual, off topic
Jim
Old 11-28-2011, 11:22 AM   #17
chevykevy
chevykevy's Avatar
Automatic Harnees SOLD
Manual harness with guages still available
Old 11-28-2011, 12:19 PM   #18
tjsblazer
tjsblazer's Avatar
re: the manual harness
1) should be the same for a 72 blazer ??
2) are there any cut/broken wires or missing connectors?
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 11-28-2011, 03:25 PM   #19
jaros44sr
jaros44sr's Avatar
If you buy it, hold your old harness side by side and compare each wire, should be the same, but not totally sure, until you compare
Thanks kevy, just got the delivery confirmation number
SAFETY FIRST
AS usual, off topic
Jim
Old 11-28-2011, 07:53 PM   #20
chevykevy
chevykevy's Avatar
tjsblazer
I'm not positive about the blazer differences but I would think they would be the same. Is your truck a manual transmission? This harness is for a manual with guages. It is super clean, no issues.
Old 11-28-2011, 08:02 PM   #21
tjsblazer
tjsblazer's Avatar
It is currently an Auto but I'm collecting parts to convert it to manual. Going to try to find a little more info.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 11-28-2011, 08:05 PM   #22
chevykevy
chevykevy's Avatar
Sounds good
Old 11-28-2011, 08:06 PM   #23
chevykevy
chevykevy's Avatar
What else do you need for the conversion? I may have it. I think i have a pedal assembly. I'll have to look
Old 11-28-2011, 09:43 PM   #24
tjsblazer
tjsblazer's Avatar
Thanks. I think I have everything right now except wiring.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 11-28-2011, 10:03 PM   #25
chevykevy
chevykevy's Avatar
ok
