Old 11-16-2011, 04:09 PM   #1
IOWNATRUCK
Exhaust pipe size?
Stock Exhaust O.D. on a 1984 Chevy C10 stepside? 2.5 inch?
IOWNATRUCK is offline   Reply With Quote
Old 11-16-2011, 07:10 PM   #2
Prerunner1982
Prerunner1982's Avatar
Re: Exhaust pipe size?
Yes I do believe that is correct. My 82 C10 had 2.5"...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 11-16-2011, 10:38 PM   #3
IOWNATRUCK
k thanks.
Old 11-17-2011, 03:42 AM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
its double wall tubing from factory so inside diameter is close to 2 1/4
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-17-2011, 03:42 PM   #5
Malo83
Cruzzzn' Vet
Malo83's Avatar
3" single exhaust on mine
Malo83 is offline   Reply With Quote
Old 11-17-2011, 07:43 PM   #6
Prerunner1982
mine ended up with 3" duals...
Jon
Oklahoma Roll Call
Old 11-26-2011, 01:30 PM   #7
75gmck25
Stock iron manifolds have 2" fittings, so they usually use that size pipe for the whole system if it has full duals. If it runs into a cross-over and a single pipe, I'm not sure how much bigger that pipe is. Most of the aftermarket duals from Hooker and other companies use 2 1/4" pipe, since it will handle engines up to about 325-350 hp.
Some folks (and manufacturers) add larger tips on the pipes to make it look like bigger pipe. My Mustang has 2 1/2" dual pipes, but you can get up to 4" factory tips to put on the mufflers.
Bruce
75gmck25 is offline   Reply With Quote
Old 11-27-2011, 02:33 AM   #8
asphaltburner
asphaltburner's Avatar
Mine's aftermarket, built by Ken's in Ft Collins for me via my requirements.
2.5" duals with "H" pipe, straight out the back. Hookers provide the flow. Perfect.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
