Old 11-27-2011, 10:08 AM   #1
67gmcstepside
WTB 1piece drive shaft 4x4
Finishing up changing over from a t221 to np201 and it's tiMe to find a drv shaft. The axle is a 1/2 ton 72 and need the drive shaft to fit np205 - 72 axles.
Thanks, Don
67gmcstepside is offline   Reply With Quote
Old 11-27-2011, 11:12 AM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: WTB 1piece drive shaft 4x4
Measure your yokes, and take a center to center measurement. Any good driveshaft shop can make one up for you.
Dunenutt is offline   Reply With Quote
Old 11-27-2011, 12:04 PM   #3
1967chevyswb
1967chevyswb's Avatar
may have a driveshaft send me center to center measurements and i will double check for you
1967chevyswb is offline   Reply With Quote
Old 11-27-2011, 01:20 PM   #4
67gmcstepside
Can't get measurements right now as the trans is on my work bench getting a rebuild. A stock 70-72 should fit as I am changing out the tc to a 205 and the axles are 72's.
Old 11-29-2011, 01:26 AM   #5
1967chevyswb
I have a complete driveshaft that is 50 inches from u joint to u joint
Old 11-29-2011, 07:03 AM   #6
67gmcstepside
Great, thank you. I will be done with my trans rebuild this week and hopefully have it installed this weekend. I will get the measurements. What would you be asking plus shipping to 08527 NJ?
