Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-27-2011, 06:06 PM   #501
litew8
litew8's Avatar
Re: Junkyard Jimmy Super Low Buck Build Thread
very cool
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 11-27-2011, 11:47 PM   #502
hgs_notes
GEARHEAD
hgs_notes's Avatar
Todays progress report. Here's where I started...
The inflated football got the basic shape of the bedside back, but the wheel well arch was a complete mess yet. For that I used a combination of hammers, dollies, blocks of wood, pliers, etc. I made enough improvement with that to bring me to the point where I could say to myself, ok, this should work out. Which would justify soldiering on, which meant stripping paint so the stud gun would be effective and make it easier to "see" my work without the rust and paint lines. Which got me here...
During the stripping my buddy from the body shop stopped by to check my progress. He was shocked and offered me a job. I told him he couldn't afford me. He said to just take my time and keep on and gave me some tips for working with the puller.
A couple things I learned today, first the slide hammer can be used for more than just sliding the hammer for pulling. I figured out that if I just used my weight to jerk it back it was probably more affective. There is less shock on the stud because the force isn't just banged on and as for weight and force, I think I can generate more energy jerking my 245 lbs back than the couple pounds of the slide hammer.
Second, you can put the slide hammer on the stud and give it steady pull and use a hammer around that spot to knock down some highs. Kind of similar to having a dolly on the back side. Anyway, here's where I ended the day...
Not done yet, but it has come a long way and if I keep working it I won't even have to use a ton of mud on it to get it smooth.
hgs_notes is offline   Reply With Quote
Old 11-28-2011, 02:05 AM   #503
VA72C10
VA72C10
VA72C10's Avatar
That's a 1000% improvement. You must have a great sense of accomplishment!!!
Old 11-28-2011, 10:46 AM   #504
Tynee
I miss this truck.
Tynee's Avatar
Whoa...
I'm absolutely blown away.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 12-02-2011, 01:13 PM   #505
hgs_notes
GEARHEAD
hgs_notes's Avatar
Taking a day off today and got back to hammering on my bedside. Heres where I started the day...
I just cut off the studs in the areas that I don't think will help it anymore, cleaned it up and sprayed some rattle can etch primer on it so I could see better where I was at. Borrowed the stud gun again but didn't use it yet today. I also borrowed a long handled dolly and a good body hammer and started banging away at it. It's much better than yesterday, but still has some issues to work out. The circled areas are high bulges (the ones above the wheel well will pop in and out). The lines are low areas. I think I'm within 1/8" on almost all of it. The top of the wheel arch is in and I need to figure out how to pull it out straight. Coming along better than I ever imagined though.
Old 12-02-2011, 03:48 PM   #506
rondog4416
rondog4416's Avatar
wow what a great job your doing !!!! keep it up !!!
rondog4416 is offline   Reply With Quote
Old 12-03-2011, 12:36 AM   #507
1956cameo
1956cameo's Avatar
Nice work!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 12-03-2011, 01:11 AM   #508
hgs_notes
GEARHEAD
hgs_notes's Avatar
Originally Posted by 1956cameo View Post
Nice work!
Thanks guys. Got another hour or so out in the garage. I wanted to try a shrinking technique on a couple of the bulges above the wheel well. Those in particular because they would pop in and out. If I tried to push them in, them mudded it smooth and later they popped out, I think my mud work would pop out with it. So to stabilize those areas I needed to shrink the steel back after it was stretched with the tree or rocks that smashed it in.
First I tried using the stud gun with a different tip that is like a button. Just rest it against the spot you want to heat, push the button and heat it up, pull the gun away and lay a wet rag on the spot to cool it and the steel will contract or shrink. I used it in 3 spots and it did help. It was most effective in the spot where the wheel tub bolt was pushed through the outer skin.
Wanting to see if I could get the bulges to flatten out more I used my little propane torch to heat a bit larger area, layed a wet rag on it and I think it helped some. There are still high spots there, but they seem pretty stable. No longer popping in and out.
With that done I decided to see what I could do with the back end of the panel. It was smacked in bad also and the worst of it was right at the top rear by the reverse light. Heres where it was when I started...
I took out the reverse light assembly, and used pry bars, dollies, hammers, punches, pliers and anything else I thought would help get in to the back side of those dents. I got the worst of it out. So now I'll strip off the paint there, clean it up and use the stud gun and puller to get it close enough to smooth out with a thin coat of filler. I'm pretty happy with how it turned out so far.
Old 12-03-2011, 01:28 AM   #509
67chevy1series
67chevy1series's Avatar
nice! come work on my bedside!
67chevy1series is offline   Reply With Quote
Old 12-03-2011, 04:22 AM   #510
VA72C10
VA72C10
VA72C10's Avatar
You are turning into a regular body man!!! Great work!!!
Old 12-03-2011, 12:15 PM   #511
litew8
litew8's Avatar
Great progress for a few days.
Old 12-03-2011, 02:01 PM   #512
1972hays
1972hays's Avatar
looks good i like this tread a lot and your jimmy
72 chevrolet 4wd 350/350 swb fleet green mean army machine
1972hays is offline   Reply With Quote
Old 12-03-2011, 10:01 PM   #513
bollybib
bollybib's Avatar
I've been watching your work in this thread for quite a while but haven't posted. I like your style. You're sort of like an alchemist; transforming junk into gold. Bravo.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 12-04-2011, 05:17 PM   #514
Mt Man Chad
Mt Man Chad's Avatar
GREAT WORK, keep it up....
Looks like night and day.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 12-04-2011, 10:06 PM   #515
hgs_notes
GEARHEAD
hgs_notes's Avatar
Do you even have a bed for your truck? lol
I don't know about "regular" but maybe irregular.
Yep, just a few hours beating the snot out of it and it fell into submission.
Thanks.
Thanks for posting. Dpending on how much time I put into it, it'll be in the range from tin to gold. I'll be happy if it at least has more value than the cost to build it, which is a rare thing with these trucks.
I'll keep hammering away. I'm having some trouble getting the top of the wheel arch outward a bit more. If I can get that, the rest is a piece of cake.
I'll probably get back to it tomorrow. Thanks for the kind words and encouragement everyone.
Old 12-05-2011, 01:17 AM   #516
67chevy1series
i see you have been following along! LOL i dont have pictures but it does have a bed on it now
Old 12-08-2011, 09:52 AM   #517
hgs_notes
GEARHEAD
hgs_notes's Avatar
Last night I took an hour to strip more paint and hammer more dents. The area above the taillight was a layer of old filler. Looks like someone beat it with a hammer. Borrowed the stud gun again and pulled most of it out. That area s hard to do because of te thickness of the steel and the sharp bends. The studs won't stick hard enough to pull it hard, but I got it much better. Also added studs to some of the other areas that were low and got it smoother. I'll postsome pics later when I finish getting the old paint off and have it all in primer.
Old 12-10-2011, 09:16 PM   #518
hgs_notes
GEARHEAD
hgs_notes's Avatar
Got most of the old paint off the the bedside and cleaned off the studs for the puller work. Sprayed with the last of my rattle can etching primer. If you look close with a critical eye you will see lots of dings and it is no where near done. From here out though it will primarily be body filler work and some hammering on the high spots. I need to finish up the inner lip of the wheel arch and weld the inside panel back in place.
I also need to decide how to handle the front of the wheel arch. Both sides were cut for tire clearance. I could leave as is (not), or just put a flush patch in to close it up and maintain the tire clearance (maybe) or cut a patch from a truck bed and replace it back to original (maybe).
Where I started from...
Old 12-11-2011, 02:30 PM   #519
Tynee
I miss this truck.
Tynee's Avatar
transformed
Old 12-13-2011, 11:33 PM   #520
hgs_notes
GEARHEAD
hgs_notes's Avatar
Got back under the wheel well to tack the inner and outer panels back together. No major problems, but I think I'll be cutting some of the tacks to get the arch pulled in more on the front and back. I think if I leave the top of the arch where it is, I can move the other areas in a bit to get a flatter opening all around. It's hard to see in any pictures and maybe I'm focusing too much on it, but I think it'll be worth the extra effort.
With the panels welded together, it was easier to pound on it some more and try to get the high spots down some. I did more work around the tail light area also. It was pretty messed up. The damage on the side pulled on the corner, which was also smashed inward. It resulted in the edge by the tailgate getting pulled outward, the outside corner pushed in, the bottom corner of the light opening was in about 1/4". A lot of pry bar, hammer, pry bar, hammer to get it out where it's supposed to be. Started putting some filler on it too. More tomorrow and some sanding to see just where it all ended up.
Old 12-16-2011, 11:20 PM   #521
hgs_notes
GEARHEAD
hgs_notes's Avatar
Are you guys as tired of seeing pics of a banged up bed side as I am working on it? Took a day off today and did some mud work. Slowly building layers up and have most of it roughed in. Ran out of time with sanding my last layer, but it looks like I'll be able to finish it with just a bit more filler or maybe even a glaze coat and it'll be ready for primer. I decided not to worry too much about the wheel arch and the front where it was cut because I think I'm going to try and get a set of flares for it eventually. Future plans include coil over suspension with links and larger tires (waaaaay future).
First couple layers just to see where I was at, blocked with a 12" board.
Then a skim coat over most of the damaged area, blocked out again and I have just a few little spots that need some fill. I don't think there is more than 1/8" of filler in any area. This next pic shows a magnet sticking to it in what should be the thickest layer of filler.
Still need to add some filler on the back corner, but it is very close now. I'm hoping to get it straight and in primer this weekend. Fingers crossed.
Old 12-18-2011, 10:29 PM   #522
hgs_notes
GEARHEAD
hgs_notes's Avatar
After several attempts to fill all the lows and bang down all the highs, I finally got some high build primer over it. It's still very rough at this point, only used 100 grit so far with a 12" board, but I think it will be ok in the end. Definitely wont win any shows, good thing that isn't the plan.
The wife is really liking the copper colors, and I happened to catch a show this morning that had a 1939 ford with a 2 tone copper and silver paint job. The copper was PPG Copper Penny and she really liked that.
Anyway, pics of the progress.
Last of the regular filler work...
After a few coats of primer...
(That line in front of the marker light is not a dent or wave, just where my spray pattern ended and the light catches it)
After that hammer fest the rest should be a piece of cake.
Old 12-18-2011, 10:32 PM   #523
67chevy1series
wow you saved that hole bedside! wish mine could be saved!
Old 12-18-2011, 11:21 PM   #524
VA72C10
VA72C10
VA72C10's Avatar
Super work! Looks really good and keeps with the low buck theme nicely. You should be proud!
Copper sounds cool!
Old 12-22-2011, 11:17 PM   #525
hgs_notes
GEARHEAD
hgs_notes's Avatar
Anything can be saved, depends how much work you want to put into it.
Copper sounds cool!
Low buck, yep. I spent $24 on a gallon can of filler, used about 1/4 of it. For comparison, I used the same size can for my whole truck and had a bit left over. I like copper too, but I'm thinking it will look like a duracell ad with the black top and accents. PPG Copperhead is nice, but I also found a ford color that I like, 2009 Amber Gold metallic and the newer trucks have a golden bronze that is ok, but too brown I think.
Todays progress, took me about 15 minutes to pound out the next major dent. Not the easiest spot to work in, but you can reach it with a pry bar through the side marker hole.
Just banged away from the back side until it came out, then had to beat the side in some, which pushed in the side some. I should have braced that inside with a piece of wood or something first. Always learning something. It'll pop out ok with the stud gun and puller. You can see in the straight on pic that the gap with the tailgate is not even. It spreads as you go down, and the outside edge of the brake light opening is bowed out yet. I'll weld the crack up at the top of the opening and keep working it. But definitely an improvement. Amazing what you can do with a hammer and pry bar.
