Old 11-21-2011, 10:28 PM   #1
space wrangler
77 4x4 cab swap
i have a 77 4x4 that needs a new cab. ...luckily, i have access to an 84 cab via a neighbor, but i'm not exactly clear on how to make the hood, doors, and fenders from the 77 work with the 84 cab.
will the 77 one piece hood even fit over the cowl on the 84 cab?
space wrangler is offline   Reply With Quote
Old 11-21-2011, 11:04 PM   #2
Tex_50613
Redneck Customs Bumpers, IA
Tex_50613's Avatar
Re: 77 4x4 cab swap
un-bolt the cowl and cab side of the hood hindges from the 84's cab and bolt on the 77 front clip, my 85 K20 had a 76 front clip on it when I bought it and my 85 K30 ccdrw is getting a 75 front clip when I get to that point
also the plastic screan that is under the cowl on the 84 can remain on the cab without hindering anything
Overkill is under rated, Redneck Customs Truck Club Hudson, IA
"Clifford" 83 Chevy K20 4x4, Mudder 7" lift rolling 44's
"Basterd Child" 86 Chevy K30 4x4 crue cab Dule, 7.3l international WIP
'00 ex-cab Silverado 4x4 DD
I hate red trucks but you can't tell by looking at what I own
Tex_50613 is offline   Reply With Quote
Old 11-22-2011, 08:37 AM   #3
xrcr
Re: 77 4x4 cab swap
x2 I have an 84 cab on a 76 2wd, other than having to massage my"inexpensive" aftermarket parts, it all bolts up. Being a tightwad makes a lot of work....
xrcr
xrcr is offline   Reply With Quote
Old 11-23-2011, 04:34 PM   #4
72shorbox
Re: 77 4x4 cab swap
You will have to swap out the wiper transmission also.
72shorbox is offline   Reply With Quote
Old 11-23-2011, 06:03 PM   #5
Tex_50613
Tex_50613's Avatar
Re: 77 4x4 cab swap
you can use the one on the 80's cab at which point I recomend using a pair of 87-91 burb or blazer wiper arms with the sprayers on them, thats what I ran on mine and still run in it instead of the sprayers in the hood
Old 11-28-2011, 08:37 PM   #6
space wrangler
Re: 77 4x4 cab swap
Thank you, sirs!
I bought the 84 cab and it appears everthing will work. I also got a free float 14 bolt and a 3/4 ton 10 bolt front out of the deal.
