Closed Thread
Old 11-29-2011, 12:34 AM   #4301
forestb
forestb's Avatar
Re: What did you do to your truck today?
Installed my newly designed mirror arms. The original made it so that the bar between the side window and the vent window landed smack in the middle of the mirror. So I cut about 3 inches out of the arm and welded it back together and painted it black. I think my next step is to get a 5" convex mirror head to give me great visibility.
forestb is offline
Old 11-29-2011, 01:36 AM   #4302
510hpLs
510hpLs's Avatar
[ATTACH]Name:  ls motor.jpg
Size:  33.4 KB[/ATTACH] went from one 6 to a new 6
510hpLs is offline
Old 11-29-2011, 01:06 PM   #4303
65Custom
I like the way they look, I wonder how that would work on the 4-5-6 years
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline
Old 11-30-2011, 12:07 AM   #4304
E911manager
After making a final decision to use the Caprice core support mounting hardware I cut the holes and welded in plate to hold the 64 core support. Looked over the Caprice radiator and made mental notes on how to integrate it.
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 11-30-2011, 12:16 AM   #4305
markeb01
Senior Enthusiast
markeb01's Avatar
Originally Posted by 510hpLs View Post
[ATTACH]Attachment 834940[/ATTACH] went from one 6 to a new 6
Welcome to the forum.
markeb01 is offline
Old 11-30-2011, 01:39 AM   #4306
510hpLs
510hpLs's Avatar
thanks hope to have a cool truck like everyone else on here some day
510hpLs is offline
Old 11-30-2011, 03:00 AM   #4307
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Still driving her every day, and loving it.
fryer1979 is offline
Old 12-02-2011, 10:01 AM   #4308
samuellg1977
samuellg1977's Avatar
Installed my new-to-me Deluxe heater. I have to admit, at first, I was thinking - "Man, that sure is a SMALL heater core." It didn't take long to change my mind though!! I could've baked bread in the cab this morning!! During my 20-minute drive to work, it got SO hot in the cab, I had to turn the heater ALL THE WAY OFF and roll down the window to get some relief!! I wired up the blower motor switch last night just to make some heat til today, now, I need to figure out what all the flappers and cables do and get them installed and connected.
samuellg1977 is offline
Old 12-02-2011, 10:15 AM   #4309
waspp
waspp's Avatar
I just about have the underside of the cab repaired, just one more front cab brace to go. I painted the firewall section flat steel blue and undercoated the floor while i had some warm weather. Now it's back to normal temps and I hope to tip the cab back down so I can get it in the garage but it's freakin pitch dark at 4:45 in the afternoon....sheshh!
waspp is offline
Old 12-02-2011, 10:42 AM   #4310
E911manager
samuellg1977, thank you for your military service and protecting our freedom. If it was not for YOU we couldnt enjoy the priviledge of extreme hobbies like this. Thank you...
Old 12-02-2011, 03:01 PM   #4311
samuellg1977
Thanks. All I ask is that my friends and family keep Old Glory flying for the Soldiers and the families that have paid the ultimate price for our freedom.
Sam
Old 12-02-2011, 09:08 PM   #4312
losthope
losthope's Avatar
Today i printed out and used this thread http://67-72chevytrucks.com/vboard/s...elay+headlight and wired up some headlight relays into my truck and the difference is AMAZING! My low beams look like high beams now! this upgrade is so great i already went and got another set of relays that im going to wire into my other classic car.Thanks "markeb01" for the great right up!
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline
Old 12-02-2011, 09:09 PM   #4313
narx66gmc
Painted my thermostat housing to continue the dechroming of Stanley...
Build Thread - Papa's truck build up
narx66gmc is offline
Old 12-03-2011, 09:05 AM   #4314
tincan1966
tincan1966's Avatar
The plan for today is to finish off the '69 and get it back on the road. had a slight delay,waiting for new headers. Interested to see how the new cam/intake combo improves it. Waiting on a new dual electric fan setup, but put the clutch and original shroud on for now with a new triple pass aluminum radiator. Bought a Gearvendors over/under drive off another site and should be hear by next weekend, so will be able to cruise the highway at about 2200-2400 rpm and still keep my 4.11 gears and my TH400. She is working on her little project and we hope to fire off that big block maybe tomorrow for the first time.
tincan1966 is offline
Old 12-03-2011, 11:51 AM   #4315
markeb01
Senior Enthusiast
markeb01's Avatar
I'm glad you found it helpful!
markeb01 is offline
Old 12-03-2011, 01:43 PM   #4316
doublebeetx
What kind of relay do you use for headlights ? I am not electrically inclined, so I don't have a clue. Thanks
doublebeetx is offline
Old 12-03-2011, 03:54 PM   #4317
losthope
losthope's Avatar
if you go to your local parts store ask for a heavy duty headlight/horn 30 amp relay they will get you the right ones cost around $5 each or you caan get them on ebay : http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313
Timmy D.
losthope is offline
Old 12-03-2011, 11:22 PM   #4318
E911manager
Picked up a "parts" truck today for the fleetside bed. but the truck seems to have a lot of good parts.. Spent some time cutting up the caprice radiator support and mocking it into the 64. Hopefully I will have it ready to put in tomorrow so I can start figuring out what to do with the inner fenders..
Old 12-04-2011, 12:40 PM   #4319
niterider65
niterider65's Avatar
Cool Re: What did you do to your truck today?
worked on the passanger sie sunvisor mount and striped down the rear saw bar for powed coating will take it all in next week..
niterider65 is offline
Old 12-04-2011, 12:57 PM   #4320
niterider65
here is the sway bar
Old 12-04-2011, 01:00 PM   #4321
tincan1966
tincan1966's Avatar
All went somewhat well. The '69 is running and performs great. BUT the gear drive I chose is horrible. Not the good sounding whine some like, this has more of a growl-not pleasing at all. Removing it tomorrow night and going back to chain. Was very pleased with headers- been very happy with the Patriot brand lately. Hope you all had a good weekend. Lots of cool projects going on. Hope to get back to my '65 Burb next week-had to fix shop truck first.
Old 12-04-2011, 01:06 PM   #4322
Rich 5150 69
Rich 5150 69's Avatar
If you chose a fixed idler gear drive like the sig erson, quiet one they sound a little better, pete jackson dual idler drives are notorious for some reason for he growling, even though I chose a quiet gear drive for my coupe, after several long road trips it sorta made me nuts......
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 12-04-2011, 01:14 PM   #4323
Coley
Coley's Avatar
Smile Re: What did you do to your truck today?
First....this is a great site, I'm really glad I got on board and joined. I'm really amazed at the projects and talent here.
As for one of my trucks (one is '66 one is '72), I'm in 'wait' mode for a week until a shipment gets here with a brand new grill/insert ('72) as well as new cab bushings, some chrome trim pieces and then a few used pieces. All of this is coming in from good ol' Bill Peeters of 'Bills Truck Shop', Ontario....good guy.
My '66 is in hibernation in the garage....but I'm going to hopefully fire it up and pull it out long enough to do some rustchecking on it before tucking it back in again.
As for today, well......just gonna' go out for a drive and thats about it. Given the upcoming Christmas season 'hobby' time is going to be on the downslope side so putting in the new grill/etc and the other upgrades will have to wait until January.
Keep up the amazing work and projects guys!!
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline
Old 12-04-2011, 01:19 PM   #4324
niterider65
here is the last of frome yesturday sway bar
Old 12-04-2011, 01:22 PM   #4325
Southcity
Southcity's Avatar
Agree with 65Custom, that looks great - nice little modification of stock parts.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline
Closed Thread
