Old 08-25-2003, 08:43 PM   #1
brad20653
Is this good enough?
Is this good enough for light welding duties ? Like bumpers,rocker panels,ETC. ???
Soon to have 68 SWB 350 with Turbo350
brad20653 is offline   Reply With Quote
Old 08-25-2003, 09:03 PM   #2
brad20653
Campbell hausfeld Flux Core 85 Amp Electric Wire Feed Welder
Model: WF2010
Wire feed welder provides an instant arc for easy welding
115-Volt Input plug in anywhere and saves you cost of wiring for 230 volt
30-80 Amp Output welds 20g – 3/16” steel, and is easy to match heat to metal
DC output provides a smooth weld bead for increased satisfaction and results
Duhh
Old 08-25-2003, 09:56 PM   #3
brad20653
t
Old 08-25-2003, 10:07 PM   #4
Randy70C-10
Randy70C-10's Avatar
Flux-core welders are ok if you don't mind doing alot of grinding. Mig welders are the only way to go when it comes to body work. I use a Lincoln SP-125. It's a standard 115 volt also.
Randy70C-10 is offline   Reply With Quote
Old 08-25-2003, 10:13 PM   #5
brad20653
migs do it clean /????
Old 08-26-2003, 12:14 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Flux sux!!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-26-2003, 12:29 AM   #7
crazy longhorn
Fabricate till you "puke"
You can weld sheet metal with a flux core welder......but it takes some patience! I have welded the sheet with an AC stick welder(that took a little practice!) Also like Randy said, you will do a lot more grinding. I run an sp100 Lincoln for the tin, but on the heavy stuff, it doesnt have enough "juice". i still use the old Lincoln stick welder for any bumper or chassis brackets. Good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-26-2003, 08:40 AM   #8
smokekiki
Mike
smokekiki's Avatar
It's not much more for a mig welder.Local welding supply shops have small bottles of gas that are reasonable.The gas will last quite awhile doing sheet metal.Just remember to turn it off.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-26-2003, 11:36 AM   #9
Randy70C-10
Yep. Flux core does a sloppy job and you get weld BB's bouncing all over the place. They hurt when they go inside your shoe!
Old 08-26-2003, 02:50 PM   #10
72MARIO
72MARIO's Avatar
Flux Sucks !
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-26-2003, 03:25 PM   #11
crazy longhorn
And weld BB's feel like red hot bolders in when they are your shoe(freakin OUCH!) with my mig, i weld in my work shoes(sandals).......they dont call me crazy for nothing! crazyL
Old 08-26-2003, 03:29 PM   #12
busterwivell
Get a MIG
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
