![]() Join Date: Aug 2010
Re: Start of 72 ochre Blazer build thread
Sorry, I just re-read my previous post and it is unclearly written.
The two questions I was attempting to ask you guys are as follows. 1. do I have to cut my floor patch to match that seam or can I cut above that seam since the patch panel goes above it? (not sure about structural issues within that seam) 2. That area where the ends of the floor support, front pillar, and inner rocker meet together and are bolted with 4 bolts. Can any of this be welded together or should it all be bolted somehow again? (not sure how with my current situation) Thanks in advance for any instruction on these items! |
![]() Join Date: Jan 2007
1. I did the floor patch to the firewall by cutting the floor patch to the seam and then folding it over to recreate the factory look. I would then fill it with seam sealer like the factory did. I guess you could do it without the seam...
2. The bolt area could be welded up solid if you wanted to...I know a few members have done it. It is easier to unbolt and fix the rust since all parts are 'seperate', but when years of rust have their way with a truck - they might as well be welded up anyway. |
