Brakes interchangeable ???
Hey guys, I want to know if you guys know if any of the brake parts off a 2000 ls1 camaro be able to fit on my 86 c10? I just bought the camaro to swap the ls1 with tranny but this thing has rear disc brakes with slotted rotor front and back. It also has 3:73 gears in the rear but I wouldn't use the weaker 7.5 over the 10 bolt. So can any of this stuff (gears, rear disc, abs, etc..,) change over to our setup?
I would like to use the 18's that's on the camaro too so that's why I would like swap the front rotor also. Thanks Slim Posted via Mobile Device
Long live SLIM ------------------ At least try to buy American ![]() |
Re: Brakes interchangeable ???
Even if they swapped over (no idea if they do) your backspacing on the wheels would be way off, they would be severely inside your fenders and there would be clearance issues.
I am sure someone else can chime in on the other parts.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#3 | |
![]() Join Date: Jul 2010
you maybe able to use tha caliper with tha help of someones brrackets. tha rear end i'm guessing in to narrow for a square. you could part it ot & keep stuff like wheels, seats, console, shifter & anything else you maybe can adapt to your truck. You can get some spacers/adapters & use tha wheels.
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
