Old 11-30-2011, 10:29 PM   #1
HeavyHauler
Found a 1968 SWB....
I have been looking to buy a 67-72 SWB and came across a 1968 SWB fleetside GMC with 327 auto on the floor(B&M shifter) for sale. He wants 7K for it but may be negotiable.
It has a wood bed that is weathered and starting to rot, fuel tank relocated,the frame has been c-notched with reverse spring kit in back and lowering springs up front. It has 20 inch five spoke Boss wheels with front discs with rear drums. It has some rust coming in on the passenger side rocker area,the truck runs but the engine is tired and it will need a paint job. Does the price sound good?
How can I tell if this is an original 68 GMC SWB fleetside?
How can I tell if the engine is original? (really doesnt matter too much to me)
Is there anything I should be looking at in particular before buying this year,make and model of truck?
HeavyHauler is offline   Reply With Quote
Old 11-30-2011, 10:59 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Found a 1968 SWB....
Numbers numbers numbers
For a start, give us the VIN (Should be lcoated in glovebox/frame/driver door jam). All 3 numbers/lcoations should match.
Numbers behind driver side head (if v8 i assume) post those too
John
1999 Toyota Tacoma 4x4
Old 12-01-2011, 12:13 AM   #3
68C10HotRod
68C10HotRod's Avatar
Welcome to the board!
If the VIN in the door jamb & SPID label in the glove box match, the SPID will tell you what the truck had from the factory. Whether it still has those parts will take more digging. Here's an example of my Chevy Burb. Chevy & GMC VINs are very different though. W/BASE should be 115.0 for a SWB.
IF it's really a V8 the VIN should read something like, CE10D-?B#####
C = 2wd, K = 4wd
E = V8, S = I6, M = V6
1 = 1/2 ton
0D = 67-69 Fleetside, 0C = 67-69 Stepside
- = special for PA, MA, NY otherwise left as dash
? is assembly plant letter code
B is year code (C=67, B=68, A=69, Z=70, 1=71)
# is 5 digit serial number off the line
The 327 & Auto should show up on the SPID as a line item since they weren't standard equipment. Looks like 327 was an available option too. That should give you some stuff to look at. BTW, page 10 of LMCTruck.com web site will help you decode the VIN & a few other numbers.
Look on the back side of the rockers underneath for rust. Also look at the cab supports going to frame in same area. Inside kick panel where floor meets firewall just in front of the doors. All places rust might be hiding. Good thing is there are patch panels for "almost" anything you might need if you find something later too.
Good luck on the purchase.
Bryan
'52 Bel Air 2dr HT - in pieces
'68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin
"And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery)
68C10HotRod is offline   Reply With Quote
Old 12-01-2011, 02:13 AM   #4
sameyrasmea72
sameyrasmea72's Avatar
Some rust seen maybe more, rotted wood, tired engine, and needs paint. With out looking at it, It sound too high to me. I would keep looking.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 12-01-2011, 10:27 AM   #5
eurospec1
eurospec1's Avatar
Tired engine and needs paint, 7k, is way to high IMO
68 SWB Fleet 383
eurospec1 is offline   Reply With Quote
Old 12-01-2011, 11:18 AM   #6
RenoKeene
Florida Edition
RenoKeene's Avatar
Sounds a bit high to me too. 7K will buy you a whole lot of truck right now in this economy.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 12-01-2011, 11:32 AM   #7
big_al_71
big_al_71's Avatar
sounds more like a 2k truck
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-01-2011, 12:01 PM   #8
cdowns
cdowns's Avatar
yep that's what i would guess
Old 12-01-2011, 12:24 PM   #9
OJ1988
Just a car guy
OJ1988's Avatar
I would love to get 7k for mine, and it has a new engine, trans, suspension, brakes, etc...
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 12-01-2011, 01:34 PM   #10
specialtyretail
So,, what else you got???
specialtyretail's Avatar
The best advice when looking to buy one of these old truck is to leave the emotional aspect out of it. i have seen that cause way too many people pay way too much for one. If it doesn't seem right, walk away. there are plenty of them out there, esp in the price range you are looking. good luck
specialtyretail is offline   Reply With Quote
Old 12-01-2011, 01:54 PM   #11
no moa
no moa's Avatar
That right there is the best advice i've heard yet on buying one of these, wish i had left my emotions out, i wouldnt' have gotten boned to the hill on my truck
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 12-03-2011, 02:41 AM   #12
HeavyHauler
Hey guys the truck is missing the SPID on the glove box.
SHould I be looking for VIN serial numbers on drivers side door jamb and driver side cylinder head?
Where on the frame would VIN numbers be located?
Old 12-03-2011, 02:48 AM   #13
70cst
70cst's Avatar
The SPID is the key for documenting factory options. As been said $7000 sounds high. In this economy $7000 can buy a lot of truck. Pics would be of help.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-03-2011, 09:46 AM   #14
LockDoc
The Older Generation
LockDoc's Avatar
This is an interesting thread that relates to this...
http://67-72chevytrucks.com/vboard/s...d.php?t=472743
LockDoc
Leon
Old 12-03-2011, 10:41 AM   #15
Ackattack
Ackattack's Avatar
I assume this is the truck he's talking about
http://wichita.craigslist.org/cto/2694208587.html
After looking at it, i'd say it might be worth $4k-ish
Ackattack is offline   Reply With Quote
Old 12-03-2011, 11:05 AM   #16
cfChebby
Not even close at $7K. There are a lot more sellers than buyers right now... I'd really low ball him with a wad of cash. $$$ in hand is very tempting when you have bills to pay!
cfChebby is offline   Reply With Quote
