Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 11-27-2011, 11:29 PM   #1
bakerboys
bakerboys's Avatar
engine trouble please help
have a 1993 gmc jimmy
It idles real rough untill warmed up then it runs better but no service engine light is on still does not have a lot of power but i am use to v8 but my sons 4.0 cherokee has alot more power it has 4.3 vortec
while driving down road it runs fine just idles bad until warmed up any help is great thanks
bakerboys is offline   Reply With Quote
Old 12-01-2011, 04:44 PM   #2
Tink
Tink's Avatar
Re: engine trouble please help
Is this a CPI or TBI? The CPI motors are great and have good power, but they have their own special set of issues....
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 12-01-2011, 05:15 PM   #3
bakerboys
bakerboys's Avatar
Tpi
Old 12-01-2011, 05:16 PM   #4
bakerboys
bakerboys's Avatar
I know its not the inject spiders they are new
Old 12-02-2011, 06:26 PM   #5
bakerboys
bakerboys's Avatar
ok update no.6 spark plug if firing and plug has lot of fuel on it
unplug the no.6 spark plug wire and no ch cyange to engine its running on 5 cylinders but i am getting spark and fuel and we did not find any vacume leaks anyone help me
Old 12-04-2011, 07:57 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
first we need to clarify which engine you have. 1993 would either be a TBI (throttle body injection) with the 8th digit of VIN being a "Z" or the "vortec" CPI (central port injection) with the 8th being a "W".
the CPI "W" engine having poor running/long cranking time/wet plug on #6 is usually a sign of the plastic fuel lines under the upper intake leaking since they sit right above the entrance to the intake runners for #4 and #6. you can verify this by removing the plastic cover on top of engine (2 T30 screws) and the Intake Manifold Tuning Valve. the have someone turn the key to run while you look through that opening towards the back drivers side corner with a small flashlight.
the lines are available aftermarket
http://dormanproducts.com/p-3431-551...ector%2520Line
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 12-04-2011, 08:05 AM   #7
68C15
blood type; Retumbo
68C15's Avatar
I should add though that lately I have little or no faith in Dorman stuff.
Old 12-04-2011, 10:45 AM   #8
bakerboys
bakerboys's Avatar
sorry yes it is cpi
Old 12-05-2011, 11:23 AM   #9
BarryB
BarryB's Avatar
Have you done a compression test? Just to help eliminate other problems?
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 12-10-2011, 11:41 PM   #10
bakerboys
bakerboys's Avatar
ok guy lied he never replaced spyder injector i did it today one side was a lot cleaner than other side it has good compression to
it runs alot better but still seems to have a small miss
Old 12-19-2011, 02:07 AM   #11
bakerboys
bakerboys's Avatar
Huh
Old 12-26-2011, 11:01 AM   #12
Tink
Tink's Avatar
Spammer...
Is the #6 still not firing?
69 Chevy C10
88 Sierra
02 2500 Suburban
Old 12-26-2011, 11:09 AM   #13
bakerboys
bakerboys's Avatar
I dont think so hard to tell runs better now but still missing
