seat belt questions
i have removed a few sets of 67 belts and was wondering if there should only be one plastic sleve on the inner latch lap belts like in the picture or one on each side? if only one what side does it go on? been years since i removed them and before digital cameras and i keep seeing sets for sale with only one of them. also when optioned with shoulders do the inner shoulder mounting plates go under the lap mounts so the plastic sleve can go on top? thanks for any help on this.
Moderator
![]() Join Date: May 2007
Re: seat belt questions
Interesting point....Of all the 67's I have pulled, the drivers side outer belt (female end) has had the plastic sleeve. I have never pulled a set that has had plastic sleeves on both female belts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 12-02-2011 at 12:37 AM. Reason: had it backwards...doh! |
so im not that crazy. i was sure mine only had one.
#4 | |
Roadtrip!
![]() Join Date: Feb 2003
Another question, did all 67s have the chrome, thin headed bolts?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Moderator
All the ones I have pulled have had the thin headed bolts, as they are a different thread than the 68-up. Incidentally, the 67 bolts are also the correct thread for the shoulder belts in all years.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
yes! im not crazy either! now i dont have to look for 2 that have sleeves just so i can have a "normal set" .... i already do!
even the date tags were sewn in different spots cause of the sleve. one is lower without the sleve and the other is just above the top of it in this pic.
so do you think the shoulder belt anchor would mount under the sleve then on the driver side?
Florida Edition
![]() ![]() Join Date: Oct 2010
Very good info here...
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
